Question about Garden
I have a tecumseh 8hp on a snapper handlebar rider. bought it used 2 weeks ago, got it home mowed for about 1 hour and it quit. decide to give it a tune up. noticed the coil wire was almost burnt in half. replaced coil, plug, changed oil, drianed gas, drianed float bowl, air filter, gas filter, took all covers off of motor, cleaned all old grass out of fins, i mean i did everything i colud to get it to run but it still wont fire or run. pulled plug out after trying to start it for about 30min plug is dry, no oil, gas, nothing wrong with plug. mower still wont start or run. someone please tell me what im doing wrong
  • 718 Answers
If plug is dry than you are not getting fuel to the plug something is plugged up in the carb clean it thoroughly and make your coil gap is correct. But I would lean more towards the fuel not reaching the plug.
Posted on Jul 18, 2010
Where can I get a diagram of carb choke and throttle linkage set up?
I bought a brand new 13 hp Tecumseh on my rider,was trouble from day one,fought it tooth and nail,finally took to shop,they put a brand new Taecumseh carb on it,couldn't get it to run,went to a dinky lawn mower shop,was told the carb was not the right one,wow,they sold me a used one that looked way different,but it worked super,so try another non-tecumseh carb or fight it forever.
Jun 07, 2015 | Garden
Grease plug locatiom snapper rider
if it's a rear engine rider with a 28 or 30 inch deck the grease fitting is underneath the deck... If it is a rear engine rider, close the fuel off and stand the mower on end but for a short period of time only. This applies to ALL rear engine riders from Snapper up until about 2 years ago when they made a SERIOUS mistake and redesigned them
Sep 11, 2014 | Snapper Garden
Tecumseh 8hp drive stopped have to push
Could be the belt is broke or come off or the pully loosened on the shaft. Good Luck
Jan 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Sep 27, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
165 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
