Question about 3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch
HOW DO I INITIALIZE AND/OR RESET A 3Com
HOW DO I INITIALIZE AND/OR RESET A 3Com SuperStack 3 4400 48x10/100 Mbps Networking Switch TO DEFAULT SETTINGS?
  • gracetel Jul 19, 2010
    Thank you for the help. I am going to follow the instructions you gave me. Take care.
    Guru:
  • 632 Answers
Use telnet and issue command reset system
This will reset the entire system
Posted on Jul 18, 2010
  • 4 more comments
  • gracetel Jul 18, 2010
    COULD YOU PLEASE BE MORE SPECIFIC. HOW DO I CONNECT TO THE SWITCH IN WHICH PORT AND WITH WHAT KIND OF CABLE? WHAT SETTINGS DO I NEED IN MY LAPTOP? CAN YOU PLEASE TELL ME HOW DO I SET TELNET INTO THE SWITCH? THANKS I REALLY APPRECIATED.
  • Simon Swales
    Simon Swales Jul 18, 2010
    Connect it up as you would normally on local network use laptop open Start menu Click Run type telnet
    and type the Local network ip assigned to the superstack and upon connection login is required enter admin login and type reset system
    Thank you 4 the information. My problem is that I bought this switch in an auction and I do not have any info. I beleive that all default settings such as the IP address and password has been changed. Can I somehow do it another way? Thanks for your help.
  • Simon Swales
    Use a ip scanner E.g Angry ip scanner
    And scan 192.168.1.1 to 192.168.255.255 it will take some time but then will find the ip's for devices on your local network make sure the superstack is connected to the network correctly like hook it up to the same internet.
    using login recover and password recover
    or admin and password = password
    Thank you, I ran the angry ip tool but could not find it the range I entered. I could not fix it tonight but I will come back to it next week. Is there a button you just can push and reset it. Please let me know. Thanks for your help and take care.
  • Simon Swales
    No button to push and reset, Only way to reset is using an external command tool like telnet
    to tell box to reset, A Local store if you are unable to do it may do it for a little charge if you are unsure how to link it up
I want to know the default ip address of 3com superstack 3 switch 4500 model and the default username and password of the device
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Jul 18, 2011 | 3Com 4500 24-Port Ethernet Switch
How to rest t
Connect the switch with a null-modem cable
In windows, hyperterminal , To enter into Password Recovery Mode:
login: recover
password: recover
Turn the power off (hard reset) within 30seconds
Re-enter the password twice.
Feb 23, 2011 | 3Com SuperStack 3 4228G (3C17304-US)...
Default password is incorrect or reset doesn't work
The default ip is 192.168.1.1
default user-name and password for the 5 models of 3com are as follows.:
1.
3com default ip: 192.168.1.1
username: n/a
password: admin
or
2.
user-name: adminttd
password: adminttd
or
3com default ip 192.168.1.1
user-name: admin
password: n/a
or
user-name: n/a
password: PASSWORD
OR
5
user-name: root
password: !root
ok try
this
Note that at time you will need to set your local ip of your pc from which you are acess the device to the same range...
That is for example 192.168.1.10
Good luck
uttam
Feb 26, 2010 | 3Com 2816-SFP Plus (3c16485-us) 16x1000...
Benji
sound like its fails the post.manual says should yellow if it fails, green if it passes. maybe hard reset unplug it from power wait a couple minutes plug back in.
May 21, 2017 | 3Com SuperStack 3 4226T (3C17300)...
How to recover old password on 4300 switch?
you manually RESET your device by pressing the "reset" button at the back. it will be reset to factory setting with the default password loaded.
Regards!
Jul 13, 2009 | 3Com 3C17100 /RETAIL3COM SUPERSTACK III...
Wants to reset 3824 3com switch via console
You forget the password for the "admin" user account and can no longer perform important management operations. solution.gif Use the password recovery method outlined below to define a new password for the "admin" user account:
  1. Access the Command Line Interface from the console port and enter the user name "recover" and password "recover" to place the Switch in password recovery mode. The Switch remains in password recovery mode for a maximum of 30 seconds, before it returns to the CLI login prompt.
    note.gif You must use the console port to recover the passsword. If you attempt the recovery method using the network, the password will be rejected.
  2. Perform a hard reset on the Switch whilst it is in password recovery mode by switching it off, waiting a few seconds, and switching it on again.
    note.gif You cannot use a soft reset operation to reset the password of the "admin" user account. This will end the password recovery procedure and return you to the CLI login prompt.
  3. When the Switch has rebooted following the hard reset enter a new password for the "admin" user account.
Mar 05, 2009 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Inherited 2 switches 3com 4228g (3c17403) password problem
I haven't worked with these switches but generally settings such as ip address and factory defaults can be set through the Console Interface (CLI). You will need a null-modem cable to access this and a terminal client (Windows Hyperterminal works).
Hope that helps
Dec 31, 2008 | 3Com SuperStack 3 4228G (3C17304-US)...
Doesn't POST
I've got a Superstack II 3300 24port switch, all leds are on, and led 8 blinks.
I'll let you know if I find a solution.
Dec 09, 2008 | 3Com SuperStack 3 3300 TM Networking...
3Com 3824
Download free version of HyperTerminal for Vista : ftp://ftp.hilgraeve.com/htpe/htpe63.exe
Make a new connection :
connect using COM1 (depends of your configuration)
19 200 bits/sec
8 data bits
No parity
1 stop bit
No control of flux
And push enter twice to display a "Login:" prompt.
Connect using default user/passwords : http://support.3com.com/infodeli/tools/switches/ss3/management/ug/setup.htm#13131
Regards,
AstroMan
Jan 14, 2008 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Open Questions:
Random reboot of 3com 4400 stack Can you help, please? I have a 3Com 4400 stack running the latest version v6.13S. The stack sometimes reboots randomly. The logs showed the following: Unit 1 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 42 42 6.13s S/W Watchdog (r) 17 Hrs 42 Mins 52 Secs Uptime Hours 16828 Reset 41 43 43 6.13s S/W Watchdog (r) 0 Hrs 51 Mins 14 Secs Uptime Hours 16828 Reset 42 44 44 6.13s S/W Watchdog (r) 0 Hrs 47 Mins 54 Secs Uptime Hours 16828 Reset 43 45 45 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 15 Secs Uptime Hours 16828 Reset 44 46 46 6.13s S/W Watchdog (r) 0 Hrs 18 Mins 48 Secs Uptime Hours 16828 Reset 45 47 47 6.13s S/W Watchdog (r) 0 Hrs 33 Mins 59 Secs Uptime Hours 16828 Reset 46 48 48 6.13s S/W Watchdog (r) 1 Hrs 9 Mins 57 Secs Uptime Hours 16829 Reset 47 49 49 6.13s S/W Watchdog (r) 0 Hrs 59 Mins 28 Secs Uptime Hours 16829 Reset 48 50 50 6.13s S/W Watchdog (r) 0 Hrs 42 Mins 37 Secs Uptime Hours 16829 Reset 49 51 51 6.13s S/W Watchdog (r) 20 Hrs 17 Mins 57 Secs Uptime Hours 16849 Reset 50 52 52 6.13s S/W Watchdog (r) 0 Hrs 5 Mins 19 Secs Uptime Hours 16849 Reset 51 53 53 6.13s S/W Watchdog (r) 0 Hrs 55 Mins 15 Secs Uptime Hours 16849 Reset 52 54 54 6.13s S/W Watchdog (r) 0 Hrs 37 Mins 23 Secs Uptime Hours 16849 Reset 53 55 55 6.13s S/W Watchdog (r) 1 Hrs 26 Mins 17 Secs Uptime Hours 16850 Reset 54 56 56 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 12 Secs Uptime Hours 16851 Reset 55 57 57 6.13s S/W Watchdog (r) 17 Hrs 26 Mins 34 Secs Uptime Hours 16868 Reset 56 Assertions : Id S/W Rel File Name Line 5 3.00 agg_sma.c 1215 6 3.00 agg_sma.c 1215 7 3.00 agg_sma.c 1215 8 3.00 agg_sma.c 1215 9 3.00 agg_sma.c 1215 10 3.00 agg_sma.c 1215 14 3.00 agg_sma.c 1215 Last System Error Data: ID (57) S/W Rel (6.13s) Reason (S/W Watchdog) Unit 2 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 236 236 6.13s S/W Watchdog (r) 0 Hrs 10 Mins 55 Secs Uptime Hours 48145 Reset 235 237 237 6.13s S/W Watchdog (r) 2 Hrs 2 Mins 20 Secs Uptime Hours 48147 Reset 236 238 238 6.13s S/W Watchdog (r) 0 Hrs 29 Mins 15 Secs Uptime Hours 48147 Reset 237 239 239 6.13s Power (r) 2 Hrs 0 Mins 0 Secs Uptime Hours 48149 Reset 238 240 240 6.13s S/W Watchdog (r) 17 Hrs 5 Mins 9 Secs Uptime Hours 48166 Reset 239 241 241 6.13s S/W Watchdog (r) 2 Hrs 55 Mins 1 Secs Uptime Hours 48168 Reset 240 242 242 6.13s Power (r) 3 Hrs 0 Mins 0 Secs Uptime Hours 48171 Reset 241 243 243 6.13s S/W Watchdog (r) 91 Hrs 47 Mins 28 Secs Uptime Hours 48262 Reset 242 244 244 6.13s S/W Watchdog (r) 45 Hrs 25 Mins 25 Secs Uptime Hours 48307 Reset 243 245 245 6.13s S/W Watchdog (r) 4 Hrs 29 Mins 38 Secs Uptime Hours 48311 Reset 244 246 246 6.13s S/W Watchdog (r) 117 Hrs 3 Mins 10 Secs Uptime Hours 48428 Reset 245 247 247 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 9 Secs Uptime Hours 48428 Reset 246 248 248 6.13s S/W Watchdog (r) 3 Hrs 11 Mins 54 Secs Uptime Hours 48431 Reset 247 249 249 6.13s S/W Watchdog (r) 20 Hrs 52 Mins 50 Secs Uptime Hours 48451 Reset 248 250 250 6.13s S/W Watchdog (r) 3 Hrs 5 Mins 37 Secs Uptime Hours 48454 Reset 249 251 251 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 13 Secs Uptime Hours 48455 Reset 250 Assertions : Id S/W Rel File Name Line 129 6.10s lazy_ack.c 890 137 6.10s poller.cc 1104 138 6.10s poller.cc 1104 152 6.10s lazy_ack.c 890 158 6.10s lazy_ack.c 890 159 6.10s lazy_ack.c 890 169 6.10s lazy_ack.c 890 170 6.10s lazy_ack.c 890 173 6.10s lazy_ack.c 890 175 6.10s lazy_ack.c 890 187 6.10s lazy_ack.c 890 191 6.10s lazy_ack.c 890 199 6.10s lazy_ack.c 890 208 6.13s lazy_ack.c 890 209 6.13s lazy_ack.c 890 225 6.13s lazy_ack.c 890 Last System Error Data: ID (251) S/W Rel (6.13s) Reason (S/W Watchdog)
May 14, 2009 | 3Com SuperStack 3 4400 (3C17204-US)...
3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch Logo
618 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
