Keybord connection outlet on back of PC (HP Kayak XA 6/400 Slot1 DT) is loose & not allowing use of keyboard . I want to replace it. I need guidance on disassembly of PC to replace this part, & cost of new part. Thank you. sincerely, Jeff Missonellie jmissonellie@pvsc.com 973-817-5757
  • 149 Answers
Dont try to replace, its soldered to your motherboard so youll have to replace the whole thing. Just buy a USB keyboard.
Posted on Apr 21, 2008
About keybord
check the keyboard settings are correct. eg a US keyboard setting will give the @ symbol where the " symbol is. look in control panel/ keyboard/language settings for your options
Dec 23, 2013 | HP 15.6" Compaq Presario CQ58-A10NR Laptop...
Changed the battery in a scion xa and the alarm keeps going off when the battery is connected back
Scion XA PDF Manuals online Download Links at Scion ...
scionmanuals.com/scion-xa-pdf-manuals-online-download-links/
Here at Scion XA PDF Manuals online Download Links page,intended to offer Scion XA Owners available Electrical ... Scion XA 2004,2005,2006,2007,2008:
How To Replace Scion XA Key Fob Battery 2004 - 2006 ...
? 1:45
www.youtube.com/watch?v=1AWHK_flb9s
Aug 4, 2014 - Uploaded by Keyless Entry Remote Inc
This video will show you how to replace a key fob battery for a 2004 2005 & 2006 Scion XA.
Jan 21, 2013 | 2005 Scion xA
Half my keyboard won't work cq50
The keyboard in the laptop must be replaced, go to www.ebay.com Type: make and model, refine search to keyboard.
May 14, 2012 | HP Compaq Presario CQ50-103NR Notebook PC
My keyboard is not working right keys E,D,C,3,F4 &F5 are not responding when I use it, thats why i'm using on-screen keyboard often times.
It could be a bad connection. The keyboard is usally pretty easy to remove. On most labtops it can be removed with a small screwdriver along the edge of the keybord. It is connected to the motherboard with a brezel connector, check that it is not loose. If you cant find the fault you can normally find a replacement keyboard on ebay for as low as 20 bucks.
Take a look at this guide
Mar 23, 2011 | Toshiba Computers & Internet
Was using my Hp Pavilion dv7 laptop, suddenly turned off while the charger was plugged in. Turned back on then shut off again. Now my laptop wont even turn on, and there are no lights that even come on,...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | HP Pavilion dv7-1245dx Notebook
The back space key dos not work
Replace the keybord. Or just go to a Electronic's Shop and buy a
USB Keybord.
(you can get a wireless keybord too)
Feb 13, 2010 | Microsoft K5100141 Keyboard
Keyboard suddenly didnt work
First make sure battery works fine .
Reattach battery .
Then uninstall wi fi keybord driver.
Then reinstall from disk which come with keybord when you purchase.
Installing driver fix keybord problem .
Let me know if you need further assistance.
Thanks.
Oct 28, 2009 | Belkin F8E206 Keyboard
Keyboard doesn't work
If you have droped any kind of liquid on the keyboard get it replaced
Apr 17, 2009 | Computers & Internet
Keyboard and touchpad stop workin
you can check with function key or try connect other keyboard to your lap possible your keybord i broken and you need exchange for new one
Aug 08, 2008 | Computers & Internet
Compaq Presario v2405us Laptop keyboard help
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
Jan 07, 2008 | Compaq Keyboard
Computers & Internet Logo
David Payne
David Payne
