Question about Whirlpool LER8648P Electric Dryer
Dryer doers not heat on any setting - Whirlpool LER8648P Electric Dryer
    President:
  • 1,382 Answers
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse which is about an inch long is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Thank you !!
Posted on Jul 18, 2010
Dryer is heating but only half of what it should
Most of the dryers has several heating coils that are linked and then each coil is activated by the heat settings. So if your dryer is heating but not like it should that means either the heating coil or the temperature setting switch.
Jan 23, 2012 | GE Dryers
It is a ab doer 2 not the twist one , I bought it used and I need to know how to put it together
Here is the instructions manual straight from the manufacturer:
www.thane.com/manuals/ab-doermanual.pdf
I looked into this quite a bit and could find no difference between the ab doer twist and the ab doer 2.
Hope this helps.
Aug 02, 2011 | Sport & Outdoor - Others
Heating elements won't heat up. the settings are
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | Amana NED5400TQ Electric Dryer
The dryer turns but no heat on either setting
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 20, 2010 | Abbaka White Knight 44AW Electric Dryer
Dryer only heats on the highest heat setting
Some electric dryers have two heating elements. You probably have one bad heater and one good heater.
Apr 14, 2010 | GE DVLR223 Dryers
When hooked up to water supply faucet doers not have pressure
Take the water saver out. it restricts the flow of water. it is underneath the screen. Unscrew the spout and take out the screen. above the screen there's a little piece that's round with holes in it. Remove it and put the spout back together. hope this helps!
Jan 04, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
Our model 110.62822101 220 v electric dryer doers not seem to heat very warm. The heating element is not broken and measures 11 ohms. Any ideas?
HI. There are a few areas i would advise to check to resolve this issue.
The dryer uses multiple thermostats to regulate the temperature. When the temperature is higher than the preset limit of a particular thermostat, the thermostat breaks the circuit and the heater goes off. When the temperature cools enough, the thermostat closes the circuit again and the heat can come on.
Most dryers have a choice of temperature settings, therefore a separate thermostat is used for each setting. The selector switch or timer control then routes the circuit through the appropriate thermostat.
If a thermostat fails, it may prevent the heat from coming on, or cause long drying periods This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, This is called a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again. The most common cause of overheating and long drying periods, will be a clogged ventilation assembly. Be sure to inspect the entire ventilation Assembly for build up. This will cause issues, if obstructions exist.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
To test the thermostats or fuse, set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. At room temperature, the thermostats should have a reading of zero. When the thermostats are heated to their limit temperature, they should switch off and you should get a reading of infinity. The fuse should be tested at room temperature for continuity.
Dec 25, 2009 | Kenmore Dryers
Kenmore dryer won't heat on low temp
Hi , the high temperature causes the heat sensor does not work properly , in delicate setting are having heat , the heat sensor are busted or open elements was not heating .
Jan 25, 2008 | Dryers
Whirlpool LER8648P Electric Dryer Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
