Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I have a john deere 325 with a kawasaki 18hp v twin the engine bogs down and the runs fine . ihave changed the fuel filter checked the needle and float and the inside of the carb is clean ichecked the plugs one was ok the other plug was black and alot hotter than the other plug . any suggestions
John Deere L120 runs for 15 minutes, bogs down and dies. A few minutes later starts right up, runs for a few minutes and dies again. I have changed the fuel filter, all fuel lines, air filter, cleaned the...
Is this an older machine ? If so try finding the points its usualy on the front lower part of the engine behind the cover, if you see that then it needs its condensor replaced, lookes like a round battery.
If this is newer or you can also try changing the spark plug sometimes they heat up and fail.
Sep 17, 2012 | John Deere Garden
I have a john deere tractor with a Kawasaki 20HP V-TWIN that will run on starter fluid, but will not start normaly, I replaced all the fuel related items on the engine, including rebuilding the carb,
recheck your jets also check the needle valve seat they swell up and stop fuel flow next replace the solenoid with a short bolt and try that they might sound as they are working but don't
Aug 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
John deere x 300 carb needs adjustment
If you want to solve your problem, click on the link I attach.
JOHN DEERE X300 SERVICE REPAIR MANUAL
Apr 20, 2017 | John Deere Garden
Engine seems to run fine but when mower is engaged it loses power. It is a john deere 325.
Check to see if the mowing deck spins free or somewhat free with the engine off, It might be wrapped up with twine or something stopping from spinning, this will bog down the engine. Hope this helps.
May 29, 2011 | John Deere Garden
Idle hunting
I feel that with the description you have given, that the problem lies with your carby.
It's either
- the choke is coming on
- the carby needs a service. Either a shaft is sticking or the fuel jets are blocked.
- low engine oil
these could all cause the above problem
Apr 04, 2010 | Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
222 people viewed this question
Top John Deere Garden Experts
Wayne Fellows
Wayne Fellows
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a John Deere Garden Expert? Answer questions, earn points and help others
