Question about Casio FX-115ES Scientific Calculator
How to calculate 0.3log(base 2)0.3 using fx-991ms calc
  • Casio Master
  • 7,993 Answers
Your calculator knows only the decimal logarithms log or log_10 and the natural logarithms (ln or log in base e).
So you cannot compute directly the logarithms in any bases other than 10 and e.
A workaround consists in using the relation
log in base b of a number a (log_b (a))
log_b(a)= (log_10(a) ) / (log_10 (b))
or the relation
log_b(a)= ln(a)/ln(b)
log_2(0.3)=log(0.3)/log(2) where log is log in base 10
Similarly
log_2(0.3)=ln(0.3)/ln(2)
As to the multiplicative factor you had at the beginning of your expression, just multiply the value obtained by one on the formulas above (both formulas will give the same result) by 0.3
Posted on Jul 24, 2010
    New Friend:
For fx 991ms users finding log 2 base 1024 press log1024 divided by log2.......
Posted on Feb 21, 2013
For fx-991ms users in finding 0.3 in base two you press log 0.3 divided by log 2(log 0.3/log ).
Posted on Mar 05, 2012
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
Floating point number into binary in fx-991MS
I checked in the manual and found that this calculator does not support Base-N calculations. On the FX-991ES Plus, which has a Base-N mode, fractions , exponents, and other floating points are not supported. The non-integer part is chopped off.
Jan 23, 2014 | Casio FX-300MS Calculator
Casio fx 991ms
On a fx-991MS? With many other models, including the fx-991ES, I'd say you have the calculator in binary mode but the 991MS doesn't have such a mode.
Aug 03, 2013 | Office Equipment & Supplies
How to do binary, octal, hexadecimal conversions in fx-991ms
Press MODE 4 to enter the BASE-N mode. Select the input base. Enter the number. Press =. Select the output base and see the result.
Jun 11, 2012 | Casio FX-115MS Plus Calculator
How 2 find mod value in casio fx-991ms
there is one button ab/c beneath CALC... if u want to calculate 7 mod 4 then... u should press 7 then ab/c 4 and equal to
u get 1,3,4 and ans is center number... result=3..
Jan 16, 2011 | Casio FX991MS Scientific Calculator
How to calculate ln using fx-991ms
Hello, There is a key for that, the one labeled [ln] for natural logarithm. For log in base 10 use the key [LOG] [LN] 10 [ENTER] gives 2.302585093. As you certainly know, you cannot take the logarithm of a negative number, nor of Zero.
Hope it helps.
Nov 01, 2009 | Casio FX-300MS Calculator
How to calculate logrithm of base of any number in fx-991ms
you need the change of base formula:
log base b of m is ln m / ln b
So- to find log base 2 of 8, simply find ln8/ln2
(from Wikipedia - the proof also follows if you want to go look it up)
While there are several useful identities, the most important for calculator use lets one find logarithms with bases other than those built into the calculator (usually loge and log10). To find a logarithm with base b, using any other base k:
Oct 06, 2009 | Casio FX-300MS Calculator
M mod n in Casio fx991MS
1, 3 ,4 which is 4*1=4 and 7-4=3 remainder...
Jun 29, 2009 | Casio FX-115MS Plus Calculator
Doubts
how to calculate antilog in fx-82MS
Nov 18, 2008 | Casio FX-300MS Calculator
How to calculate log value in calculator with different base value
In any scientific calculator log2(n) can be  calculated with either ln or log function as follows
Log2(n)= ln(n) / ln(2)
Or
Log2(n)=log(n) / log(2)
both will give nearly the same answers
Dec 08, 2007 | Casio FX-300MS Calculator
Casio FX-115ES Scientific Calculator Logo
7,352 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
