Question about Acer Aspire 3680 Laptop
Dvd drive not writing
I have an aspire3630 series laptop, it has a philips DVD+-RW SDVD8441 drive, the drive is able to read only, during write operations using nero express (ver 6) the message shown is that write operation successful but data verification failed.....on reading the dvd after writing the message shown is "BLANK DVD"
PLS ADVICE
  • Anonymous Apr 25, 2008
    Have the same problem in aspire 3630 series.
Bluetooth have a problem acer aspire 3680 xp
Posted on Apr 26, 2008
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
I am probably doing something wrong. I want to use a DVD RW to store data but it seems the MS Media center is all I have. Is there a way to use these types of removable storage like a CD-RW? Could I need...
You can use programs like Nero to burn data onto a disc such as a CD-RW. Since you already have a DVD burner you can even use a DVD-RW to burn your data
Aug 26, 2008 | Computers & Internet
I have a sony VGN CR-220E which re upgrade to vista ultimate that i could not install the webcam driver ?
According to the spec. it should be OK. Don't forget to download the drivers from Sony.com otherwise it won't work correctly.
Learn more about the Sony VAIO VGN-CR220E/P Model BrandSONY SeriesVAIO CR Series ModelVGN-CR220E/P General ColorCosmopolitan Operating SystemWindows Vista Home Premium CPU TypeIntel Core 2 Duo T7250 2.0G Screen14.1" WXGA Memory Size2GB DDR2 Hard Disk200GB Optical DriveDVD Super Multi Graphics CardIntel GMA X3100 Video MemoryShared memory CommunicationModem, LAN and WLAN Card slot1 x ExpressCard /34 Slot Dimensions13.2" x 9.8" x 1.25-1.67" Weight5.5 lbs. TechIntel Centrino Duo Mobile Technology CPU CPU TypeIntel Core 2 Duo CPU SpeedT7250(2.00GHz) CPU FSB800MHz CPU L2 Cache2MB Chipset ChipsetIntel GM965 Display Screen Size14.1" Wide Screen SupportYes Display TypeWide XGA Resolution1280 x 800 LCD FeaturesXBRITE-ECO technology Operating Systems Operating SystemWindows Vista Home Premium Graphics GPU/VPUIntel GMA X3100 Video MemoryShared system memory Graphic TypeIntegrated Card Hard Drive HDD200GB HDD RPM4200rpm HDD InterfaceSATA Memory Memory2GB Memory SpeedDDR2 667 Memory Spec1GB x 2 Max Memory Supported4GB Optical Drive Optical Drive TypeDVD Super Multi Optical Drive InterfaceIntegrated Optical Drive SpecDVD+R DL Write: 4x max
DVD+R Write: 8x max
DVD+RW Write: 8x max
DVD-R Write: 8x max
DVD-RW Write: 6x max
CD-R Write: 24x max
CD-RW Write: 16x max
DVD±RW: Yes (DVD±R DL/DVD±RW/DVD-RAM)
CD Read: 24x max
DVD Read: 8x max
DVD-RAM Write: 5x max
DVD-R DL Write: 4x max
DVD-RAM Read: 5x max Communications ModemIntegrated V92/V.90 Modem (RJ-11) LAN10/100Mbps WLANIntel PRO/Wireless 4965AGN Network Connection (802.11a/b/g/n)
Jan 01, 2011 | Sony VAIO VGN-CR220E/P Notebook
Does my laptop have a dvd burner
Can I have your laptop model number.
You can also confirm the same by looking at the drive externally
If it has DVD-RW and DVD-RW DL on it then it can read and write CD/DVDs
DVD - R ROM then it can read DVDs but cannot write.
CD-ROM/ CD-RW cannot read / write DVD
Aug 08, 2009 | Acer Computers & Internet
I want new laptop to write CDs - spec says DVD-ROM
http://reviews.cnet.com/laptops/lenovo-thinkpad-t41-2379/4507-3121_7-30567436.html
Thats the spec for yout laptop, if you have the plug-on module then you can write on it.
Optical Storage
  • Type CD-RW / DVD-ROM combo - Plug-in module
  • CD / DVD read speed 24x (CD) / 8x (DVD)
  • CD / DVD write speed 16x
  • CD / DVD rewrite speed 10x
Good luck
Nic
Apr 27, 2009 | IBM ThinkPad T41 Notebook
Replaceing a philips dvd rw sdvd8441 in a laptop 1. How can I remove Philips dvd+-RW SDVD 8431 from my Fujitsu Siemens Amilo M 7405 laptop? 2.Where can I find a compatibily new one? My product type is:...
what happened to ur current drive is it not reading the dvds why dont u try cleaning like this
open the dvd tray u see that eye like shiny thing clean in circular motions gently with soft cloth or tissue and try the dvds see if it reads it is a normal remedy otherwise change the drive if it doesnt help
normally there is one screw below the dvd drive i mean just beneath just take it out and pull ur whole drive unit out not just tray whole drive and replace it with any drive on ebay u can get it around 50 $ u can also fit any brand not just philips but u should look out for the bezel design (front panel ) u can also flip the front panel with the new one if all dimensions are same normally this slot is universal in size hope it helps u can ask for more
pls rate me FIXYA for help
Mar 29, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Unable to Write DVDs on my Packard Bell Easy Note Skype edition
dear mohan,
You may find the freeware program burnatonce quite helpful, for its info tools provide you with detailed information of the drive's capabilities,
for there are many burnable dvd's out there.Install
the program, let it check your drive.
To me it looks like it supports only DVD+R and DVD+RWs, but I may be mistaken.
Good luck, you'll solve the problem
Oct 21, 2008 | Computers & Internet
Philips DVD /-RW drive, model SDVD8441 not working
well go to google.ca and type DVD/RW drive model SDVD8441 driver free download.
thats all i did when mine failed.
Oct 02, 2008 | Computers & Internet
Acer Aspire 3680 Laptop Logo
128 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
