Question about Canon PIXMA MP530 All-In-One InkJet Printer
White spots on scanned photos
From the time I began scanning photos on my (still new) MP830, there have always been white spots (obviously dust) all over the scanned photos. I've repeatedly dusted both the platen & the photos, & I've cleaned the platen with a mild detergent solution & dust-free cloth. When looking through a magnifying glass, I see no dust on the topside of the platen or on the photos, but I do see a few small irregularities in the glass, which look like scratches. There are too few of these scratches for them to be the only source of the problem. I also see dust under the glass. Is it possible for me to clean the underside of the platen? Any other suggestions? Thank you, Sherry Sweeton
  • ssweeton Apr 22, 2008
    I'm very grateful for your response. I tried the "Reduce Dust & Scratches" setting on low, medium & high. Unfortunately, it didn't make a bit of difference. Thank you, Sherry
    I just noticed that this is posting under MP530, whereas my printer is an MP830. I doubt this will make a difference in troubleshooting, but I may as well try.
  • 2,016 Answers
There's probably nothing you can do for dust under the glass, but in the Advanced settings for your scanner, there is an option to turn on "Reduce Dust & Scratches", with three different 'strengths'. You may want to try this to see if it helps.
Posted on Apr 21, 2008
White spots on scanned images
First thing you should do is to check whether the original image is clean and no dust or anything.
The next one is to clean the scanner glass. Use a clean cloth to wipe the scanner glass to make sure there is no dust or anything that might reflect the light from the scanner that can cause white spots.
Please give us update regarding this issue.
Thank you,
Jack
Feb 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
White spots on scanned pictures. how to fix?
better change the glass of your scanner to avoid this problem in thw future and one more thing when ever you are not using the scanner put a soft cloth over glass and cover it or put a A4 size paper it will avoid dust and scratch try this
Jun 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
Canon MP830 not scanning
It won't scan unless you have a program like picasso running on your computer to accept the scan. On the Canon you choose where you want the scanned image to go and if you choose the computer you need a program running to store or adjust the scanned image.
Jun 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanning photos into computer at a large size?!
This sounds like you are trying to scan images at a larger size than they actually are?
I am not an expert-(but I have a Mac)-but from what I'm reading, scan your photos at a 300-600 dpi resolution, then use photo editing software to enlarge them. The higher the resolution, the more disk space and the more photo detail (i.e. cracks, dust, scratches, paper type) will be captured, and the more time it will take to scan. Also, for the white, does your scanner allow you to select the area/define borders during the pre-scan? Mine lets me drag borders to just the image area (but capture the image first, then do the cropping and editing to a copy later).
Rookie2112
Dec 11, 2008 | Canon PIXMA MX310 All-In-One Printer
I have a panasonic kx-mb781 mutilfunction printer,fax,scan,copier and everytime i print i get 2 white lines down the pages every time in the same spot. what could cause this?
Check the spongy black roller inside the machine for dust, wipe with a dry cloth.
Open your document feeder and check for dirt on the white bar.
Sep 11, 2008 | Panasonic Office Equipment & Supplies
Poor quality scan? Tips for cleaning this device
You can clean the scanner glass with warm water and a dust free cloth. Is the line always in the same spot in your scans? Could be something else other then dirty glass.
Aug 26, 2008 | Lexmark X1240 All-In-One InkJet Printer
Vertical white lines in scanned image
Did you try cleaning the little glass strip where the documents go in? Lift the button panel and wipe the glass with rubbing alcohol and cotton swabs or lens paper if you have it. Mine does this sometimes when dust or white out or little bits of paper get stuck on the glass.
Apr 25, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Dirty scans
Small white dots would indicate progressive failure of the CCD[sensor] or perhaps ingress of dirt to the inside of the glass. hard to say exactly with out seeing the machine.
Jan 13, 2008 | Epson Perfection 3200 Photo Flatbed...
Vertical lines through scanned images.
You should clean the small glass under the top lid. Chances are there is some white out or ink or mark on the glass. Look carefully because usually it is just a small dot>
Dec 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,317 people viewed this question
old marine
old marine
