Question about Toshiba Satellite L500 Series Notebook
I'm trying open my Toshiba Satellite L500D; I am having a problem I have removed all the aparent screws but I can't seem to lift the keyboard from the laptop. Ids there something else attaching it that I have missed?
    Brigadier General:
  • 10,406 Answers
Check the "top" edge of the keyboard -- that part closest to the hinges & the LCD screen.
There may be a few "tabs" going "under" something.
Gently push the keyboard towards you, so that those tabs can be adjusted to move "over" that something.
Then, gently lift the keyboard -- there probably is a small and delicate ribbon-cable connecting the keyboard to the motherboard.
AVOID breaking/damaging that ribbon-cable.
Posted on Jul 18, 2010
How to fix unworking TAB KEY
Try to spray "a little" wd-40 around the area, & wipe off all excess.
Feb 08, 2013 | Toshiba Satellite A135-S2276 Notebook
How do I change a keyboard on a satellite A85-S107 laptop?
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Satellite A85-S107 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Satellite A85-S107 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Satellite A85-S107 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
Mar 12, 2012 | Toshiba Satellite A85-S107 Notebook
Toshiba satellite c655 hinge replace
If you don't have the experience on disassembly the Toshiba Satellite c650 c655 laptop, we suggest you refer to the official maintenance manual firstly if you have. Here we provide a universal instruction for the reference, some steps may be not the same. If you need a detailed guide or manual, please contact us, we will email you if we have.
1. Please turn off your Toshiba Satellite c650 c655 laptop, disconnect the power adapter and remove the toshiba satellite c650 c655 battery.
2. Turn the laptop over. Remove the screws (may not exist) that hold the Toshiba Satellite c650 c655 hinges on the back of the computer.
3. Remove all the screws (may not exist) that hold the keyboard and keyboard bezel in place, then gently pry keyboard bezel using a flat head screwdriver. Lift the keyboard and unplug the keyboard cable from the motherboard to remove the keyboard. Now, you will see the toshiba c650 c655 laptop fan
4. Detach both hinge covers using your fingers. Unscrew the screws securing the Toshiba Satellite c650 c655 hinges to the laptop base.
5. Locate the screws on the LCD, pry the rubber screw seals using a flat-head screwdriver. Unscrew the screws attached under the seals. Remove the screen bezel.
6. Remove the screws securing the hinges d to the Toshiba Satellite c650 c655 LCD.
7. Now, you can remove the old Toshiba Satellite c650 c655 Hinges by sliding them out. Insert the new hinges in their correct place. Reverse the above procedure to assemble the laptop.
Mar 11, 2012 | Toshiba Satellite C655-S5068 Notebook
Hi I need to know how to turn on Wi-Fi on my Toshiba Satellite L500D? can you help please?
The L500D seems a bit tricky about its WiFi. You will find several people with a similar problem - some of them succeeded in fixing it, but it depends on your particular OS and setup:
http://laptopforums.toshiba.com/t5/Networking-Wi-Fi/Toshiba-Satellite-L500D-Wlan-wireless-problem/td-p/88570
May 18, 2010 | Computers & Internet
How do I replace the keyboard on a Toshiba Satellite L25-S1215 laptop?
1) Disconnect power and remove battery.
2) Remove the screws indicated in red behind the hinges on the laptop (on the back side above the battery location) As seen in this pic:2d7ab9f.jpg
3) In the battery compartment area unscrew the screws circled in red. Then open the laptop screen slightly so that the whole laptop is in an upside down "V" shape. Unhook the plastic tabs circled in green. As seen in pic: 685d923.jpg
4) Open the screen all the way so that it is parallel with the main body of the laptop. Gently take off the plastic piece above the keyboard by lifting it up in the areas indicated by the yellow arrows. As seen in pic: d17b74a.jpg
5) Lift out keyboard and remove ribbon cable from connector. Be careful not to break cable retainer/tensioner. As seen and described in pics: (first pic is what you see after lifting keyboard)
(This second pic shows and describes how to remove the cable safely from the connector)
6) After connecting new keyboard, reverse the order of steps to assemble.
I hope this is enough detail to help you get the keyboard replaced
Feb 08, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
How to remove keyboard on Tosh A60?
Above the keyboard you should find the thin cover which you have to remove. This is called the keyboard bezel.
Get a fine flat headed screwdriver and gently lift the bezel up from the right hand side of the laptop above the keyboard. Once you have lifted one side gently pull the bezel off with your fingers.
Under this cover you will find two screws which secure the keyboard. Remove these screws and lift the keyboard up.
Please be careful. The keyboard is connected to the motherboard with the flat ribbon cable.
Regards.
Nov 11, 2009 | Toshiba Satellite A60 Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
The m and caps lock keys on my Toshiba satellite
Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
Oct 11, 2009 | Toshiba Satellite A40 Notebook
How to open a Toshiba Satellite M-100 ?
The key move for that buddy is the cover above the keyboard, usually snap-in type, after that the screws for the keyboard and every thing follows,need to remove some bottom screws for further exploration.Need your vote
Aug 29, 2009 | Toshiba Satellite M100-ST5211 Notebook
Toshiba Satellite L500 Series Notebook Logo
304 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
