Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Tv still turning off blinking three times after ic removal
My Panasonic pt-53wx53 shuts off and the red light blinks three times, the picture does not come on at all. I removed ic's picture comes on then shuts off after 2 seconds and the three blinking lights again. I replaced all the convergence resistors also. What is the problem?
  • miketv10 Jul 26, 2010
    I replaced the horizontal output ic. I still have the same problem. What should I try next?
  • 10,515 Answers
The 3 blinking lights on your model can mean several different things, I have seen it cause at least 3 that I know of...
The first and most common is the convergence circuit, to repair this you will need to replace both convergence output IC's, normally you can determine that this is the problem by turning the set on while watching in the back, a lot of times there is a resistor in the convergence circuit that will glow bright orange.
If it is not the convergence then I have seen a problem in the vertical and horizontal circuits this will require troubleshooting though to know what is going on, most likely this will require the replacement of the vertical output IC or a cap in the horizontal circuit. I do apologize that it wasn't as easy as you were hoping, unfortunately that 3 blink can mean many different things, basically the set is going into shut down but what circuit is causing it will need to be troubleshot to know for sure.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 18, 2010
  • 10 more comments
  • miketv10 Jul 18, 2010
    So what is my next step?
  • taran_2005
    taran_2005 Jul 18, 2010
    Thanks for your response!!
    You need to troubleshoot vertical and horizontal circuits. Do you have the schematics for this Model?
    Let me know,so that we could proceed.
    Hope i helped you.
    Thanks
    I do not have the schematics for this television.
    Could I just replace the cap and output ic? Or would this not be cost effective? I already purchased new convergence ic's.
  • taran_2005
    Most of the times, i have found Vertical output IC or a cap in the horizontal circuit to be at fault. You could try to replace these and see, if that would work.If not, revert and i would be glad to assist you.
    Hope i helped you.
    Thanks
    Any idea how I would find either of those things?
  • taran_2005
    You could check radio shack or fry's for the same.
    Hope i helped you.
    Thanks
    I meant on the board.
  • taran_2005
    I do have the schematics for the same.I might need to arrange it, if the below pictures would not help you.
    Vertical output IC
    http://www.fixya.com/Uploads/images/71AF...
    http://www.google.com/imgres?imgurl=http...
    Hope i helped you.
    Thanks
    mine does not look anything like the first picture. I have a pt-53wx53
    I found the vertical output ic. I will order it. Is the cap near?
    The vertical output ic in my television is LA78045 3U8.
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
PT-53WX53G still shutting off-3 blinks
have you checked the 2.2 ohm 2watt resistors? If the led blinks three times the resistors will almost always have at least one that will be blown and need replacement.
Jul 27, 2010 | Panasonic PT-53WX53 53" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Aug 14, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Pow lite flashes three times it tries to turn on then shuts down
LED 3 times blinks shows problem with convergence out section in TV and may requires convergence out ICs replacement.
If you are familiar with TV repair and can solder parts on PCB then let me know to provide you more technical info.
Thanks.
Jul 23, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Red light blinks 5 times!!
C509 .47uF Mylar 250Volt. Replace this cap, this should restore power.
Jun 04, 2009 | Panasonic PT-53WX53 53" Rear Projection...
My Panasonic tv pt53wx53g wont turn on it blinks 3 red lights
The 3 blinks is a error code for the convergence circuit. You can get the convergence repair kit for your model at the following link which contains both Convergence ICs and all six feed resistors and they include step by step instructions with pictures that show how to do the repair yourself. Heres a link to the proper kit for your model Panasonic.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-2/cName/convergence-repair-kits
Jan 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Tv trouble
djbone30, you need two STK392-110 convergence amplifiers.
Sep 25, 2008 | Panasonic PT-53WX53 53" Rear Projection...
PT-53WX56
yes the 3 blink error code means the convergence ics need replacment. very easy you need two stk392-110 ICs and six 2.2 ohm 2watt resistors very easy an inexspensive repair. you can get replacement ICs and resistors at the following link with free instalation instructions with pictures so you can do the repair yourself and save quite a bit as a repair shop usually charges between 4 and 600 dollars for the repair which takes about an hour. Heres the link.
Aug 05, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
