Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Where is the ignition module on a 1998 chevorlet pickup k1500 5.7l?
  • Chevrolet Master
  • 1,057 Answers
The module is in the dist. You need to remove the dist. cap and rotor the module will be the black (normally) half moon shape device with the two wires attached on the advance plate for the dist. Hope this helps.
Posted on Nov 03, 2015
    New Friend:
Where is the ignition module on a 1998 chevrolet pick-up truck k2500
Posted on Aug 30, 2013
No spark on a 1998 Jeep Cherokee Sport w/ 4.0L
Have you checked the computer for trouble codes ?
Could be a long list - pickup module, coil, ignition module, distributor, rotor, power relay, etc.
Jun 28, 2012 | 1998 Jeep Cherokee
Engine no spark
If the engine has no spark, check for voltage at the coil positive terminal when the ignition key is on.
If there is voltage, the problem is on the trigger side of the coil (pickup, crank sensor, ignition module or primary wiring circuit).
If there is NO voltage at the coil, the problem is on the supply side (the ignition switch or ignition wiring circuit).
Apr 22, 2012 | 1998 Dodge Ram 1500 4WD
98 chevorlet lumina runs good for about 15 to 20 minutes a shuts off
If the fuel pump is still making a noise and the engine doesn't start when hot. Possibe Crank Shaft Position Sensor. (not real nice to do) Can also be the ignition module but more often its the Crank Sensor. There are some simple tests if you are handy with cars?
Aug 05, 2011 | 1998 Chevrolet Lumina
Where is the crank sensor on a 1991 s-10 pickup with a 2.5 4cyl engine
This year of truck, does not have a crank sensor, if no fire to plug's check ignition module or distributor pick-up assembly..
Jul 14, 2010 | 1998 Chevrolet S-10 Pickup
Put replacement 5.2L engine in 98 durango and have no spark
Be sure the ground strap is connected then check with a voltmeter that the wires going to the distributor have power if so the ignition module or some ignition component is bad magnetic pickup in distributor or coil.
Sep 11, 2009 | 1998 Dodge Durango
98 s-10 2.2 Fuel Pump Pressure
40 psi good lower than that bad
Apr 21, 2009 | 1998 Chevrolet S-10 Pickup
1998 Dodge Ram 1500 has fire from coil but not to plugs. pickup seams ok.
The ignition module is probably bad. Remove it, and take it to a local parts store, they will typically test it for free.
Mar 24, 2009 | 1998 Dodge Ram 2500 2WD
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
193 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
