Question about Hotpoint RLA30 Compact Refrigerator
HOTPOINT RLA30 FRIDGE
The fridge makes a low constant noise like it is working but it does not get cold.
Can you please advise
My Hotpoint refridgerator is 10yr . The frezzer side works fine but the refigerator side is not getting cold. Can this problem be fixed?
Posted on Aug 29, 2008
    Scholar:
  • 149 Answers
Is the noise like a hum? touch the compressor if it is really hot, suspect relay/overload combination defective touch the little line that comes out of compressor if cold, suspect the above. if you change the relay/overload combination, and works fine there's your problem. hope to se of some help.
Posted on Apr 21, 2008
Hotpoint fridge RLA30 frozen milk on lowest setting
sounds like you need a new thermostat for your fridge. If your fridge wont shut off on its own than yes its most likely your T-stat. Hope this helps
Feb 15, 2013 | Hotpoint Refrigerators
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Swap door sides on hotpoint future RLA30 fridge?
tip unit over on side,placing an old blanket or similar on floor under unit.there are 3 little bolt/screws holding each bracket to the underside of unit,unscrew these/lay brackets on floor, slide door down off pin on underside of top.and unscrew this pin.change over from right to left replace door onto pin replace bottom hingepin,adjust door for" squareness " and tighten all screws lift back upright and switch on...will take a little time to settle down temp wise.... make sure seal sits tight all round good luck ..geoff
Feb 19, 2010 | Hotpoint RLA30 Compact Refrigerator
How to change the thermostat on a Hotpoint RLA30 fridge
It is behind the knob your are adjusting to change the temperature.
It is very easy for me. Don't know how easy for you and your electrician friend.
Apr 20, 2009 | Hotpoint RLA30 Compact Refrigerator
RLA Future Hotpoint Fridge
This may be caused by a fanmotor touching something, or one of the copper tubes from the compressor causing a resonant frequency. If you touch the different tubes to find out which one is causing the noise and then slightly bend it with your fingers. That should stop the noise.
Mar 13, 2009 | Hotpoint RLA30 Compact Refrigerator
RLA30 Fridge freezing food on lowest setting
From the symptoms ,I would recommend that you have a new thermostat fitted.
This is the cheapest option., fig's do not go wrong that often
Any comment welcome.
Thanks and a merry xmas.
Nov 09, 2008 | Hotpoint RLA30 Compact Refrigerator
Hotpoint RLA30 Compact Refrigerator Logo
288 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
