Question about GE Washing Machines
GE Adora Front Load Washing Machine won't draw tap cold water
I noticed that my GE Adora Front Load Washing Machine will not draw water when I set it to the tap cold setting. If I put it on cold then it draws the water for the cycle. Anyone have this issue? Any suggestions?
zeusfaber
  • 247 Answers
SOURCE: Fabric conditioner still in draw after wash cycle
This is usually a matter of pulling the drawer right out (it is designed to let you do this) and taking it to bits (it's designed for this too). Most front-loaders have a bit of a design weakness in that the bit that gets blocked with conditioner isn't immediately obvious without a little bit of prior dismantling. Once you get the top off the drawer, you'll almost certainly find the siphon tube gummed up with old conditioner. Clean this up under a hot tap, then reassemble and all should be well. A.
Posted on Apr 25, 2007
  • 641 Answers
SOURCE: Maytag Washing Machine
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Posted on Sep 06, 2007
SOURCE: Karcher 620M not drawing water
my 620m has a problem when i press the switch on it has no pressure and the pump sounds like it is not kicking in .... plese help !!!
steve ..
Posted on Jul 31, 2008
SOURCE: GE Adora Front Load Washing Machine Problem
I had a similar problem...with the added issue of the door not locking at all. I cleaned the filter and all is well. However, it took me hours to find the 3 screws everyone was talking about The screws are at the very bottom of the washer, under the lip, facing front. If your machine sits on a pedestal drawer like mine, they are located between the machine and the pedestal. I hope these pics save someone a little time...
Posted on Aug 27, 2008
  • 151 Answers
SOURCE: GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
Posted on May 03, 2009
GE Adora front load washer turns until water is added then won't turn or spin
You should contact GE or qualified appliance repair center to be looked at professionally.
May 06, 2012 | GE Wh12x10309 Heater for Adora Front Load...
Have you tried a full hard reset? This is simply unplugging the unit from the mains for a couple of hours.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | GE WSXH208A Front Load Washer
Model WPRB9220C draws cold water when it's supposed to draw hot.
Your hot water inlet solenoid has failed and needs replacing.
Mar 11, 2012 | GE WPRB9220C Top Load Washer
What is the meaning of "tap cold" and plain "cold"?
tap cold is the temp of the water right out of the tap
cold is what is used by the machine as cold
some machine will actually raise the tub temp to 60 degrees
by adding hot to a cold fill
Oct 04, 2009 | GE WSXH208A Front Load Washer
Cold wash/rinse selected, but only hot water is used
I have a Sears front load washer and I also noticed that on a cold wash/cold rinse cycle the machine was drawing hot water.
Laundry detergents require water to be at a certain temperature to aid in disolve. The machine adds sufficient hot water, regardless of the cycle, until that temp is reached. If I was to use a cold water detergent the machine, because it has no way of knowing which detergent I'm using, will still add hot water until that minimum temp is released. I don't know if there are machines available which include detergent type as an option?
Sep 28, 2009 | Kenmore Washing Machines
My GE Adora front loader- our clothes stink!
Clothes washing rules for mildew stink: 1) never leave clothes in machine for more than a few hours 2) never add too many detergent or clothes 3) clean the machine itself. Also if your fabric softener port is gummy there is a good chance you got some funk from that so clean all places where you have fabric softener contact. After all that, if this doesn't help you may need to run an empty load of strong hot bleach water and follow it with a hot empty rinse then a load of whites
to becareful not to ruin your colored clothes
Aug 09, 2009 | GE WSXH208A Front Load Washer
Water left in washer
You must change new pump.
Feb 15, 2009 | GE WSXH208A Front Load Washer
Whirlpool washer problem
it sounds like you cold inlet need replaced its a easy job
Jan 10, 2008 | Whirlpool AWM6100 Front Load Washer
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
108 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
