Question about Toshiba 52HMX94 52" Rear Projection HDTV
Flashing Screen on Toshiba 52hm94
I got a Toshiba 52hm95 from a buddy for practically nothing the other day. He said there was an issue with it that appeared to be the lamp was going out. The screen is not very bright, and there is a white flickering that occurs, especially when the picture is dark or black. However I was playing around with the settings and turned the lamp mode from high bright to low power and all the color was distorted and mostly green. Does anyone know what this might be? Is there any way it is just the lamp or is it color wheel or something more serious. Is it worth fixing or should I haul it to the dump.
tvtek
  • 1284 Answers
SOURCE: Red?Green picture
If you are connected to a HD cable box or sat. rcvr. using component cables, I would then suspect a loose or bad blue connection or cable. If you have Comcast and have their supplied flat component cable this is a common issue.
Posted on Feb 13, 2007
SOURCE: My set switches from low lamp to bright lamp on its own constantly
I just got mine back from the shop withe a similar issue. The picture would dim especially with dark scenes and you could actually hear the lamp popping and clicking. It was not consistent enough that I had to video tape the issue for the technicians. In short, they decided that the ballast was faulty, unfortunately, the only way to replace the ballast is to replace the entire light engine. The part is about $320 and they also replaced the lamp for $150. The extended warranty would have only covered parts I believe so you may have ended up OK.
Posted on Aug 15, 2007
techman
  • 3130 Answers
SOURCE: Toshiba 65hx81 65" Rear Projection tv. black & white color/green
Yep, your problem is a relatively easy one to repair if you know how to solder. You better repair it before it blows the fuse though. There are two capacitors in the main power supply that are coming loose and need to be re soldered. There is a Toshiba service bulletin about it. They are marked C809 and C810 on the main power supply board. Good Luck
Posted on Sep 05, 2007
SOURCE: Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Posted on Dec 09, 2008
SOURCE: toshiba 62hm15a- bright flashes
my toshiba 62HM15A has bright and dark flashes.
Posted on Jun 21, 2009
How long does it take to check for dead pixel for a TV?
A dead pixel s obvious as you are aware.
Toshiba have rules regarding the amount of pixels allowed before a replacement screen is issued. There is no time limit for checking a screen but normally a Toshiba Service Centre would look at the screen within a few days if not while you wait and make a decision.
It really depends if they are the seller or not. If they are the seller, they may kick their heels a bit as they have to do the work for nothing if under warranty.
Contact Toshiba and raise a complaint.
Laptops LCD Televisions Projectors Medical Imaging More Toshiba America Inc
Apr 16, 2018 | Televison & Video
My golf buddy has stopped working can't charge nothing on screen
repairing it is not practical, have a new one purchased . thanks .
Mar 01, 2016 | GPS
My tv isnt coming on. first it was a flashing blue light. Manual said it was the fan, checked and it's fine, now no led and no screen. Fan is still running though...
same TV same problem!! Only my LED is still on and flashing. The screen never actually turns on. I'm not sure if you tried to turn it off but I did and about 5 seconds later it will turn itself back on. Again, manual says it's the fan.. I popped the back open checked it and cleaned it but still nothing. Maybe trying to reboot but I left it on for 2 days straight and nothing came back to life. I just took it to a repair shop this weekend so I guess we will see! I will post any answer they give me!
Dec 01, 2015 | Toshiba Cinema 65UL610U 65" 3D 1080p...
My toshiba laptop comes up only with black screen nothing elese
Hmmm, I'd suggest that your PC "may" have screen issues.
Try connecting an external monitor & then re-start the PC.
Mar 11, 2015 | Toshiba Computers & Internet
Toshiba Tecra M5 Boot Problems
man you push alt+ Ctrl +p so you can get it the Bios specially where has been saw it the flash cursor you will see now BIOS normally
Jun 30, 2012 | Toshiba Computers & Internet
Hello everybody. I'm having troubles with my laptop and I am really hoping to get a solution to my problem. I have a Toshiba Satellite A350 and have so for just over a year now. It has been working fine...
Unfortunately, you're only real option for an issue like this is to contact the manufacturer. You could have multiple issues going on causing this problem. It may be something to the effect of the connections between your monitor and your computer having a short. Or, it could be that one of the components in the computer is over heating or not receiving power correctly and not allowing your computer to post (boot up). With a hardware issue like this, the manufacturer is your best be to resolve it completely.
You can reach Toshiba support for computers at (800) 457-7777 (toll-free) or (949) 859-4273
Mar 05, 2011 | Toshiba Computers & Internet
A135-s2276 wont switch on
Try contacting Toshiba, as it may be some sort of a harware issue with the touch pad or currupted driver, as you said it worked for two years running XP.
Good Luck.
Mar 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Hello, I have a Toshiba Satellite R10 laptop with XP and I just Started having an issue where the screen randomly glitches up and either just goes blank or starts flashing different colors across the whole...
Probably a driver issue. Try Windows Update and select custom. Maybe there is an updated driver available, or there could be a driver conflict (wrong driver installed). At worst, it could be an issue with your screen itself or possibly even the motherboard. But I doubt it. If you can't find anything there, try http://www.toshiba.com
Jan 29, 2009 | XFX GeForce 6200TC Graphic Card
Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Aug 27, 2007 | Toshiba TP43H60 43" Television
Open Questions:
Toshiba 52HMX94 52" Rear Projection HDTV Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
