Question about Goodman CLQ36AR49 Air Conditioner
Ive installed a new capacitor on my 3ton unit,now the breaker keeps flipping.I think i may have my capacitor wires cross! please help!!!!!!!
  • 70 Answers
A cap for just the comp, one wire form the contactor to the cap and the other wire to the comp, there should be a wire diagram. if it is for the fan and comp it will be lable fan,com,comp. one wire3 from the contwctor to common, the fan wires one to common and on to the fan side. The last on for the comp
Posted on Jul 18, 2010
My brother gave me a air compressor 220 from Home Depot I got new capasotor and I gotten the unit running but stops after 5 seconds the unit pumps up air but did not trip the breaker.
Look on the end of the motor to see if the centrifugal switch is operating. Thats the switch the motor uses to connect the start capacitor you just installed at motor startup. After it runs up to speed the capacitor is switched out . I'll bet it is not working, since you needed to replace that capacitor.
May 31, 2016 | Heating & Cooling
Rug shampoo machine keeps blowing breakers now will not power on
It sounds like you have a dead short. Check the wire, it quite often will break at the point that it comes out of the machine. The power is going straight back to the panel before it gets to the motor and that flips the breaker. It probably needs the whole wire replaced. If you can take it apart, check with an ohm meter to see which wire it broken. Do not have it plugged in while doing this.
May 10, 2015 | Vacuums
The circuit breaker for my condenser trips immediately after being flipped on. When the wires from the breaker are disconnected from the unit and the breaker is flipped on it does not trip. The...
Hello, usually the breaker will trip when there is a short to ground, this can be a high voltage wire loose and touching the metal or could be that the winding on the compressor has shorted to ground. If all the wires look secure and not touching metal that most likey your compressor is shorted to ground and must be replaced.
Jun 11, 2011 | Heating & Cooling
Breaker keeps popping when I start unit
If the unit isn't even starting up and running you have an internal motor problem, either you have wires that are crossed, switch that is bad or capacitor that is bad. Most of the time on a unit like this it is not worth going to and repairing, for the price that it cost for the parts you are better off just purchasing a new machine.
Oct 31, 2010 | Campbell Hausfeld 1,350 Psi Electric...
Outside unit is not turning on, breaker keeps flipping, What should I check next?
The first thing to look for is a swollen shorted capacitor.4c1711d.jpgCheck the compressor next, look for a broken wire, compressor terminal shorted to frame or a bad overload.4e87185.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 03, 2010 | Goodman CLQ36AR49 Air Conditioner
Condesing Unit won't run.Breaker keeps tripping.
check the fuses in you disconnect easy way if you have a meter check across line top L1-L2 should have 208-230, same on load side should have same voltage. if not bad fuse. check and see when the unit starts up if the fan spins. if so fan is probably good. if the units trips as soon as you flip the breaker the compressor is probably shorted or you have a shorted wire. if it takes a good 10 seconds i wold test the capacitor in uF. if you are not good with electric or using test equipment i would recommend calling someone. hope this was some what of help to you.
May 30, 2010 | Heating & Cooling
Internal breaker in the plug keeps clicking off, when i reset it clicks off again. ive replace the Main House breaker, thinking it may be old, but still the inline breaker keeps popping off. this Ac/Heat...
Inspect the wiring and the terminals. There may be a short circuit somewhere. If you have a tester, you may check the continuity of the two wires. Test the wires after the breaker, the part that goes to the unit.
May 05, 2010 | Fedders AER24E7A Air Conditioner
How to wire a capacitor to a condencing unit
I can help you:
1: Put a Piece of Tape on each wire. write #1 #2 #3 etc
2: do the same on the capacitor.
3: Remove Wires with insulated needle nose pliers, and take a Insulated Screwdriver and Cross it over the Terminals on the Capacitor. Its safe, it just Discharges it.
4 Remove and go to lowes or home depot and get a new one.
5:Note the "RED" dot on the old Capacitor.make sure that you hook the same wire on the new cap.
6: Install New Capacitor and, your ready to go.
Make sure you pull out the "Service Disconnect" Breaker Located on the Wall next to the condensing Unit Before you do any work. Replace when you are done..
Hope i Helped
Please Rate Me
Thanks
George
Apr 28, 2009 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
85 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
