Question about Bose RC-48S Remote
Remote control model RC48S2-27
How to program the outdoors remote to deck, no with the living room, since we used to have to audios?
I have older pioneer reciever for living room no manual how do i program remote? cu vsx095
If it is the orignal remote for it, You should not have to program it,
Dec 03, 2012 | Audio Players & Recorders
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I neid go know how to reprogram one of the controls for the tv in a room but i lost the control for the tv in my living room, in the living room i have the cable box.
jc4lifes3as
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
Remotes: Basic (Television Only)
1. Turn the Television On.
2. Press and hold the TV Power button for three seconds until the LED flashes.
3. Enter the three-digit code using the buttons on the number pad.
4. Press OK. Note: The LED will flash three times.
5. Test functionality with the TV.
6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Power Scan:
Remote: Basic Remote (Television Only)
3. Press and release the TV Power button.
4. Press and release the Up or Down Arrow on the remote until the television turns off.
5. After the television turns off, press and release the OK button.
6. Test functionality with the TV.
7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network"
Apr 16, 2011 | DISH Network IR Remote Control
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Aug 15, 2009 | DISH Network IR Remote Control
Adcom GFA-5002 is dead no lights, no anything
Check the Fuse. Unplug the AC first. If you replace the fuse and it blows again, disconnect all speakers, replace the fuse and turn on. If the fuse does not blow, chances are it is a speaker problem, Adcom builds some very solid product, I would suggest pulling the outdoor speakers and testing them.
Depending on what you are using, some outdoor speakers should never be taken out of the living room. If you still have an issue post a comment and I will help some more.
Jun 24, 2009 | Adcom GFA-5002 Amplifier
How to program Honeywell thermostat for remote sensor
Remote Sensor (Setup Function 0340): If an optional outdoor sensor is installed, the thermostat can display the outside temperature. If an optional remote indoor sensor is installed, the thermostat will display the temperature at the sensor location (the internal sensor in the thermostat is not used).
\ 0 No remote sensor
1 Outdoor sensor (display only)
2 Outdoor control sensor (select heat pumps
Dec 31, 2008 | Honeywell Heating & Cooling
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Bose RC-48S Remote Logo
488 people viewed this question
Top Bose Televison & Video Experts
George Scott
George Scott
Are you a Bose Televison and Video Expert? Answer questions, earn points and help others
