Cannot reset remote for braemar Ecostar Ducted heatin. Need to reset time and day. Would like to reset programmes also however when i hit the set button as per instructions in little book provided the remote does not move onto the clock or day to select.
The Braemar heater I have is wired directly to the control unit. The only way to reset the time is to turn of the heater for 5 minutes - the remote display should clear, and turn it back on (takes a minute for remote to come back on) the time will be flashing - use the Up and Down arrows to set the time, and SET button to set the day of week.
Posted on May 09, 2012
I had the simple 2 wire control panel (basic) installed with my Braemar Ecostar. It replaced a Vulcan CX90 unit which had a 6-wire control panel. I only used 2 wires out of those 6 initially...but then I bought a Filtrete 3M WiFi thermostat controller off eBay and wired that up with just 2 wires initially...then figured out how to wire up the 24vac to power the wifi function...it's only about $100 delivered and I'm loving it.
Posted on Jul 10, 2012
  • 2,272 Answers
Check the remote batteries.are they weak or very old.Or may be the remote button circuit is faulty.actual procedure is to press the set button and change the settings and select the required settings and make changes and set button again to save changes.But id set button is not functioning.Then remove and replace the battery in remote also replace the battery and recheck. Thanks.
Posted on Jul 18, 2010
  • jandj2712 Jul 18, 2010
    my husband has removed the remote from holder, the back looks like you can place batteries in however it has a think that looks like a phone plug connection with red green lack and white wire that plug into the wall.
    Thanks
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Unable to get Braemar Spectrolink thermostate to switch to auto
I have exactly the same problem, did you ever get an answer to this issue?
Sep 08, 2009 | Honeywell Programmable Thermostat Heater
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
My ducted heater is not working. It fires up initially but when it comes time to run the fan it just goes into wait and stays like that. It is a braemar te430. Any ideas?
Sounds like the limit or fa switch. To be sure which one, e- mail the manufacture for wiring diagram or specs. Thank-you-very-much!
Aug 26, 2008 | Heating & Cooling
Wiring a Honeywell Deluxe Programmable Thermonstat
did you mark which terminals you removed the wires from on the old stat? If not you will need to look on the furnace and see what letters they are connected to .. then connect to the same on the thermostat.
Feb 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
719 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
