Question about John Deere Garden
When starting John Deere 455 lawn tractor, runs great first 15-20 sec with normal black exhaust, then engine starts knocking and exhaust turns grey at that point i shut it down, tested this 3 diff times all with same result, prior to this, engine would not start, found blown fuel pump fuse, fuel filter was replaced at same time fuse was, any way to test at home to isolate the problem??
  • 2,100 Answers
Unless you have a diesel, the black smoke at start up is not normal, it should be white if anything. It sounds like you are burning very rich, or no air at all, check the air filter, check the fuel cond, check the governor thing, make sure it moves freely and rebounds. Change the spark plug. I don't know what else it could be without being there. The carb could be clogged up, some carb cleaner wouldn't hurt. Hope this helps.
Posted on Jul 18, 2010
John deere lawn tractor. Had a dead battery. my son tried to jump it but cables got hooked up backwards, cranked 10 sec. Now turns over but wont start and smokes under the flywheel
Because he shorted out the alternator under the flywheel. There also maybe other damage as these are not protected from reversed voltage.
Apr 30, 2015 | John Deere Garden
John deere - 455 Diesel
check your seat safety switch
Nov 19, 2013 | Garden
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
JD Model 445 - Plastic gears. After replacing the new camshaft I need to adjust the valves. Does anyone have the specifications?
Remove the plugs. Turn the engine so the pistion is at top dead center for cylinder. Clearance should 0.010 when adjusting rocker to valve. Repeat for other side. I just replaced my cam shaft if a 1993 JD445. I'm planning to run for a couple of hours then check cleanace again. Hope this helps, Gerry
Jul 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Hello my name is John. I have a 345 John Deere lawn tractor. The problem is that it starts idles rough won't idle up and does not run strong enough to move the mower. It just chugs and puffs white smoke...
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Jun 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
JD 68 riding mower
dear sir
tour bottom end is going in your lawn mower or tyoyur block is cracked. sorry but thats the truth.
May 05, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
Garden Logo
830 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
