Question about Intel BOXD102GGC2L LGA775/Xpress 200/DDR2/A&V&L/MATX Motherboard, Retail (MB-102GGC2)
Defective image I have a motherboard witch is giving some kind of interference in the screen. I have tryed to change different frequency and i ve couldn't solve the problem. Someone can help me?
  • dzarom May 29, 2008
    these problem happens where ever you are. i mean it happens in POST or after it. i try-ed to change the memory but it continues.
    thanks for your solutions
  • dio dcs May 11, 2010
    does this interference of the screen happen during POST or BOOT or after the OS is loaded
  • 152 Answers
There is ram problem video memory shared ram replace ram
Posted on May 25, 2008
Panasonic KX-TG2631al 2.4GHz cordless phone is getting interference from crossed lines from another phone and wont receive or make calls
No you need to purchase a device that operates on a different frequency-most hose phone do not change frequencies beside the Bluetooth ones, and it seems your is not. I suggest a 5.8ghz and a store that has a flexible return policy, RadioShack has a decent selection of phones around 50$ give of take, you could also go for a Bluetooth setup--Good Luck.
Jan 31, 2013 | Panasonic KX-TG2631 Cordless Phone
Im trying to to connect the internet on my wii like it usally has and for some reason it says on the wii settings 52031 and it dosent connect what do i do ive already tried the key and password so idk what...
Error Code 52030, 52031, 52032
It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
Change your wireless router's channel to 1 or 11
Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
Where is your wireless router located?
Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
Look for other devices
Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
WEP / WPA Troubleshooting
If you've tried the above steps to reduce interference and you're still experiencing problems, it's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console.
Apr 22, 2011 | Nintendo Wii Console
Have to be right next to the door for the openers to work. Changed batteries with no change.???
Sounds like a faulty receiver or interference on the same radio frequency, try turning off any other wireless devices nearby to isolate the possible source of interference. If this does not work it might be worth fitting a universal remote control on a different radio frequency universal garage remote control
Dec 23, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
My scanner copies have a vertical yellow streak covering half the page. What can I do to solve the problem ?
Lines or Banding Within the Image
If the scanner is generating lines or banding within the image during preview and/or scan, below is a list of possible solutions.
Horizontal Lines: If the lines run horizontally throughout the image, it is almost definitely interference of some kind. First thing to try is reverse the cable (Astra series only, except for 2400S), trying with and without termination as well. It could also be the SCSI card itself that is causing the interference. Try reseating it in a different slot, away from other cards. Try moving the scanner itself to another location, farther away from computer components such as monitors and CPUs. If none of that works, search for the file ?prescan.dib? on the hard disk and delete it, then try the scan again. If that still doesn?t work, follow the clean uninstall and safe mode install of our software. If these troubleshooting steps do not work, it could be a physical defect within the cable that?s generating extra interference, and the cable should be replaced. If the cable has been replaced already, it may be the UDS-IS11 itself generating the interference from being defective. Replace it.
Vertical Lines: If the lines run vertically throughout the image, it is probably a hardware problem, most likely with the scanner itself. However, follow the cable-reversing instructions above, remove the ?prescan.dib? file, and try the scan again. Often, if they are thin lines they are from dust within the optics. Open the case and blow out the dust with compressed air.
Nov 25, 2010 | Umax Astra 2100U Flatbed Scanner
A yellow vertical line on the copy, which now takes half the page.
What causes the lines in an image?
My wpn111 wireless adaptor keep dropping my router signal
There is very little you can do about this. You may not like that answer, and I am sorry for the trouble, but there are things you can try.
First, lets understand that wireless is a radio signal, much like a cordless phone. The handset has to be able to communicate with the base on a phone, and, the wifi pc's have to be able to communicate with the router. Some phones and routers (sadly) use the same frequency range, 2.4 ghz. If you have a cordless phone that operates on 2.4 ghz, or if your neighbors have one, then whenever they get a phone call, wifi goes bye bye. What can you do?
1. Upgrade your phone to a wifi friendly one, with a 2.4 ghz offset range (so that the bands are close, but not so close to cause interference) or get another frequency phone.
2. Change the frequency of the router to level 1. Usually they are AUTO or level 6. Level 1 is a low frequency, and lower frequencies usually give slower, but more reliable performance. You can choose between 1 and 11. try all frequencies to see which one gives less trouble.
3. place the router in a more centered location in the home, off the floor. Remember, this is radio. Radio antennas go into the air to receive signal, and your router is no different. A router stuck in the corner of the basement may give poor performance, while a router in the center of the home should service the home easily.
4. upgrade your wifi. Choose the wireless N router and adapters for your machines. they have better capabilities and less interference.
I hope this gives you insight into the issue. Wireless is at the mercy of its environment. Building structures, signal interference, power lines, atmospheric issues, and cordless phones can play a factor in your reception. its just like taking a portable tv thru the house and having to move the antenna around to try to get better signal. Good Luck.
Nov 05, 2009 | Computers & Internet
Lift phone to make a call, get a line tone and then loud piercing noise as I move around the room, so am unable to have a clear noise free conversation. Phone is BT Studio 1500 digital phone with answer...
try walking around the room/house and turning any other electronics off, if the interference stops, then you've found the offender! could be RFI (radio frequency interference), could also be a neighbor! if you can change frequencies on your phone, try a different one. may work.perhaps you have a computer or other electronic device that's badly shielded. you may have to replace your phone with one that operates on a different frequency, if you can't find the problem!
good luck!
Sep 29, 2009 | Lands Phones
Modify a motorola T5500 to work in different frequency
Sorry. The MHz of your radio cannot be changed. And there are no "private" frequencies available for use. However, your radio is equipped with this in mind.
There are 22 frequencies built into the T5500, along with 38 Interference Eliminator Codes. The two combined offer you over 836 choices to avoid other people. And if this is not sufficient, they also have the capability Qt filtering.
http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Page 19: Interference Eliminator Codes
Page 21-22: Qt Filter
Apr 17, 2009 | Motorola Talkabout T5500 (7 Channels)...
When i switch the moniter on i see faint lines running up my moniter ( very faint ) as if they are some kind of interference lines, my colleagues are using the same screen on the tables next to me but have...
Hi this shows your monitor has a interference by:
1) by screen refurbish frequency you may try to change this frequency from PC, go to screen setting go high level setting click monitor and change the frequency to 70(or other than 60) ,also you may try from your monitor.
2)stil trouble there, your monitor has a problem with power supply,
the capacity wave filter not very good condition. need to change 5V wave filter capacity (two),should be solved.
Dec 22, 2008 | HP L2208W Monitor
Intel BOXD102GGC2L LGA775/Xpress 200/DDR2/A&V&L/MATX Motherboard, Retail (MB-102GGC2) Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
