Question about Toro Garden
I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
I HAVE A TORO WHEEL HORSE MODEL 71223, I PUT A NEW DRIVE BELT ON, WHEN I PUSH THE CLUCTH IN THE MOWER WILL KEEP GOING WHILE IT IS STILL IN GEAR, I HAVE RECHECK EVERYTHING I DID, THE BELT IS STILL LITTLE TIGHT IN NEUTRAL, BUT DOESN'T MOVE
    Sergeant:
  • 200 Answers
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
Need a manual for Wheel Horse 520-HC!
https://lookup3.toro.com/request/request.cfm Go to this website and put in model number and you can download a manual and parts book.
May 31, 2012 | Garden
I want to purchase a drive belt for wheel horse 16-44 HXLE model 79107 where can I do this?
The belt part number is Toro 93-3884. Just search google for this part number.
They are around $50-60.Also you can purchase from sears . com
or here: http://www.m-and-d.com/TOR-93-3884.html?mv_pc=00015
J
Mar 07, 2011 | Toro Garden
My toro 212-5 mower keeps spitting off the deck belt
You may need a new one. If that doesn't work you may have a bent pulley that's cause it to jump off or the barrings in one of your pulleys may be bad which would cause the pulley to wobble therefore throwing the belt off.
Jan 31, 2011 | Toro Wheel Horse Drive Belt For Tiller...
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower drive slips , not belt clutch, assembly. any adjustment? or anyway to fix it?
I hate to tell you this,but not much you can do. I had a toro wheel horse 12.5 hp the drive belt would slip,made it a little better by putting on new belt w/belt dressing,but would still do it especially under load or up hill,or starting in higher gear. Unfortanately,it was one of toros downfalls on a lot of models,and FYI if you think altering the tension pulley to hold the belt back more will solve it,your wrong,all that will do is make you lose use of your clutch.
Aug 08, 2009 | Garden
TORO Wheel Horse Lubrication
this is like a snapper drive it has a rubber plug that you pull out and fill with 0 grease lube meaning 0 is the weight of the grease that comes in a tube. you can get it at any little small engine repair or automotive shop.
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
569 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
