Question about Acer Aspire 5100 Notebook
Unable to boot my acer laptop.
I have an Acer Aspire 5100 laptop. Somehow, it was infected with malware, and I was unable to restore via prior system restore point. I tried running in safe mode to see if that would help, using the command prompt MSCONFIG > BOOT.INI > /SAFEMODE. After rebooting my laptop, the Acer logo comes up, and I have a black screen with a few options.
Run windows in:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Last Known Good Configuration Settings
Normal Mode
None of them work. It'll reboot itself, and the same screen with these options appear. I do not have the recovery disks needed, and Acer will not provide them for the very reason that my laptop is over three years old. I don't know what to do. Please help.
    Guru:
  • Acer Master
  • 468 Answers
Hi Mike,
Thank you for contacting Fixya. This is Anil.
I understand that your computer is infected with Malware and now the computer is not booting to normal mode.
I can uderstand how frustrating this could be and I assure I will try be best to resolve this issue.
From the statement I understand that it may happen due to hardware failure, BIOS mismatch or due to static charge. Let us try the basic troubleshooting. Turn Off the Computer, remove all the devices attached to the computer, the power cable and battrey, now holdon the power button for 15 secs (make sure adpater and battery are uplugged) it will drain out all the static charge. Now, restart the computer and keep on tapping F2 (some computers "DEL or Delete" key), you will enter to BIOS setup utility, press F9 (click "Yes", if you are prompted) and then press F10 (Click "Yes", if you are prompted), it will restart the computer to Normal mode. If still it is not booting to normal mode, then we have to perform a full system recovery & it is a distructive process as you will loose all the datas on the computer. To do so, Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
I believe the above resolution should resolve the issue, however, if the issue still persists, please contact us. We will be glad to help you.
Thank you
Regards,
Anil.B.R
Posted on Jul 18, 2010
  • shawamph
    shawamph Dec 16, 2012
    its asking for Empowering Technology Password?
Unable to boot Acer laptop. The booting starts and then there is a blank screen and a cursor blinking. Not moving forward. I pressed F12 and made it boot from hard drive. Still the same.
Hello.
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
Hope this helps.
Aug 28, 2011 | Acer Aspire 5100 Notebook
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Wont boot up and cant use restore
It sounds like a virus or spyware corrupted both your windows restore points and your partition...Do you have the discs that came with your system? I am afraid you'll have to manually restore.
Apr 13, 2009 | Acer Aspire 5100 Notebook
Acer Aspire 5100 will not log on
If you have a Finger Print scanner (on select models), it may have failed, if you do not have this device , you may have installed malware - try rebooting and after you see the Acer screen start tapping F8 to get to speacial boot menu - choose Safe Mode and see if you can log in. If still unable, you will have to perform a system recovery - Acer provides an alternate way to recover - when you start the computer you see the Acer logo screen - after this displays hold down the Alt Key by the spacebar and tap the F10 key at the top of the keyboard once or twice - this will start the Acer E-Recovery program - follow the on screen instructions.
Jan 30, 2008 | Acer Aspire 5100 Notebook
Acer 5100 4 way scrool
Try downloading the newest version of the software on Acer's website. This should fix you up.
Nov 24, 2007 | Acer Aspire 5100 Notebook
Frozen keyboard
you possibly have a spyware infection, (like a virus)
if you reboot and have the same problems, then try booting into safe mode, if keyboard still locked up, try using an external keyboard (to test your system), if the external keybard works then it may just be that your keyboard is broken (and needs replacing)
Oct 17, 2007 | Acer Aspire 5100 Notebook
Restoring acer aspire to its factory settings
From Acer customer support:
1 Ensure all Data is backed up, all data will be deleted.
2 Restart machine
3 When your unit switches back on hold down alt & tap f10 repeatedly...(on Acer icon)
4 Please wait a moment until prompted, -How would you like to restore?-
5 Please select –Restore system to factory default-
6 Enter your defined password or enter six zeros ‘000000’
7 Click ok
8 Please wait until process completed, this will take 45min – 1hour
Oct 03, 2007 | Acer Aspire 5100 Notebook
My Keyboard and mouse are not responding
try plugging in an external keyboard & mouse, hopefully that should work
Sep 15, 2007 | Acer Aspire 5100 Notebook
My Acer aspire 5100
If you are able, when the pc is booting up keep pressing F8, this will take you to safe mode and not allow the graphics driver to run. When in the safe mode options, select either Last known good configuration or start windows in safe mode. Last known good configuration should find the last good system settings, when it reboots. Start windows in safe mode allows you to go into windows using the administartor account, and then you should select system restore and restore back to the day before or just before you updated the graphics driver.
Aug 16, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
551 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
