Question about Memorex Televison & Video
Memorex MSP-TV1300 TV won't work with DVD player or Wii
I just got a memorex MSP-TV1300 TV(with no remote) from a garage sale, and when I got home I decided to try plugging in my DVD player. I did, but I got no sound or picture. I triple-checked the cables, they were in the right spots. Still nothing. I tried my Wii as well, with the same result. I know the problem is not with the DVD player or Wii, as I've re-tested them on my other TV to be sure.
    Top Expert:
  • Memorex Master
  • 39,324 Answers
You probably will discover that the Memorex TV is dead.
Posted on Aug 12, 2017
IrishDruid
  • 2712 Answers
SOURCE: Onkyo remote RC 570M
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
SOURCE: Memorex MVD2027 DVD Player - Remote doesn't work
haha I have the same problem.
Posted on Jun 09, 2008
ve3wtj
  • 147 Answers
SOURCE: Have picture, no sound
I've had this trouble too. Not sure how to fix it, but I've found a work-around:
Remove DVD.
Insert Audio CD.
Wait for audio to play.
Remove audio CD.
Reinsert DVD.
Sound should work again.
If you power off the unit, you may have to try this procedure again.
Posted on Oct 07, 2008
mediarich
  • 188 Answers
SOURCE: problem with old TV
The channel is almost always 3 or 4. Be sure you have the VCR connections correct. Just hook up the TV and VCR alone to start with and try both the VCR and DVD. Also the output of the VCR should show a blue screen.
Posted on Dec 17, 2008
  • 362 Answers
SOURCE: Can not access menu or input functions
Hi rduncan27,
I will be happy to help. 88% of LCD tv problems are with the backlight, the symptoms you described indicate a probable inverter malfunction. Lets do a simple test to check the functionality.
  1. Get the tv to a point that it is producing sound.
  2. Take a flashlight and shine it on the screen.
  3. Look very closely for a dark video image.
Let me know your findings and we can proceed from there.
Lone99star
Posted on Jan 26, 2009
Memorex Dvd Remote Codes
Hello
Setup codes for Memorex DVD with Direct TV [TC RC32] universal remote are>
20695, 20831, 21270
OK.
Oct 31, 2011 | Memorex MVD2022 DVD Player
Tip
Remote Control Problems
hi, BEARHOUSE IS HERE WITH THE Answer i Purchased a Memorex MVD2022 DVD Player at a Goodwill Store For $7.00 Dollars. I Had a Coby Model# 224 with Remote Control My Coby Quit Working the motor Drags. I had Both DVD Players on top of Each Other Tried The Remote For The Coby and The Memorex DVD Player Blinked. So I Cut off The Coby And What Did Find I Found that the Coby Remote Worked on the Memorex The Buttons Are Different But Works Good Enough For Me.
The Setup Button Eject the Disc and the >> fast Forward Button Turns it on and off
and the Program Button works For Sub Title other Buttons have other functions for The Memorex MVD 2022 Only thing You Have to work the sound From Surround System are TV.
on Feb 23, 2008 | Memorex MVD2022 DVD Player
Memorex mvd2047 dvd player - no audio when playing dvd
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Jul 23, 2010 | Memorex MVD2047 DVD Player
Memorex MVUC821 TV/DVD. Everything works except the TV.
Just bought the Memorex MVUC821 & the DVD Player will not open using the remote or front panel button!!!
Mar 23, 2010 | Memorex MVUC821 Player
I need the dtv remote code for my memorex dvd/cd player
I work for Memorex tech support. Our number is 800-919-3647.
Unfortunately, Memorex TVs and DVD players can not be controlled by universal or cable remotes. If you need a replacement remote, please call Memorex's parts distributor, Fox International at 800-321-6993 to make the purchase. If they no longer have stock, try www.remotes.com.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 09, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Need Universal Remote Code for Memorex tv/dvd/vcr
Jun 25, 2009 | Memorex MVDT2402 24 in. TV/VCR/DVD Combo
Need Memorex MVD2045 5-digit remote code
This code worked for me with the Comcast DVR-3 and the Memorex 2042 DVD player: 20831
It may work with the MVD2045 as well.
Jan 17, 2009 | Memorex MVD2042 DVD Player
Problem with old TV
Dec 17, 2008 | Memorex MT1194 19" TV
I need a philips cl034 universal remote code for memorex dvd play
I have similar problem with a Philips CL034 Universal Remote and a Memorex MVD2047. The Philips/Magnavox codes listed at this link did NOT resolve the problem. I tried all Memorex codes and tried the "all coded step-through" method. http://www.universal-remote.net/philipsmagnavox.html The above is NOT a solution, rather a note on a time consuming attempt to a solution.
Nov 12, 2008 | Audiovox 150W DVD Home Theater System -...
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
Televison & Video Logo
90 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
