Question about Maxtor Computers & Internet
I have a MAXTOR 3200 external hard drive that will not come up any more on the MY COMPUTER of my computers. I tried 3 different computers to try and get something. I was backing up to another external hard disk which has shown no problems. The REAL problem is that my wife's files are on the MAXTOR. What it does-the computer says it recognizes the MAXTOR 3200 under Control Panel/System and COntrol Panel Add hardware. I am told the usb software is ok and the computer says it is enabled. No recognition in My Computer of the drive. I was given the ULTIMATUM-get my files now! Oh Boy. What can I do? Your help is apprecieated. jbilow01@yahoo.com
    President:
  • 3,278 Answers
Hello.
Give this a try. There is a utility called "Tweak UI"
Then, click on My Computer, Drives,and check marking Drive F.
Download from here: http://download.cnet.com/Tweak-UI/3000-2072_4-10002117.html
Hope this helps.
Posted on Jul 18, 2010
I have a Maxtor 500GB. It was working ok but today the green light is blinking and the external memory is not conected with the computer. I have tried using different USB ports, conecting an desconecting...
you could disassemble the case and remove the drive. it could then be connect via an external controller such as(http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2477926&CatId=3770) and test if the drive itself is good in which case it is the controller in the case.
cheapest way I can think of to diagnose these external enclosures
GL
Don't forget to vote if I have help you,
TY
Jammer
May 25, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor Personal Storage 3200 500 GB Hard Drive suddenly not recognized. Light on, tried alternate similar power supply, tried different computer along with different operating system. Please help.
May be your Personal Storage 3200 500 GB Hard Drive power socket pins are not seated well when you connect so make sure the pins are in good condition.
Think this is helpful !
Aug 11, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have Windows XP with service pack 3. My system no longer recognizes the Maxtor 3200 external hard drive. Do I need to get an updated driver to the hard drive? When I first connected the Maxtor HD. ...
When you plug in via USB, does the USB recognize it and not display as HDD? If that is the case, then it's probably disabled somehow. Access Computer management, and check from there.
If that doesn't work, try on a different computer. If it doesn't work, your HDD has gone faulty. And if you recently changed your board, make sure you have a high speed USB port.
May 24, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 was working fine. Suddenly my
Try connecting it to another computer.
If it is not detected, then either the disk-drive "inside" the unit is dead, or the "adapter" (USB-to-Disk-Drive) inside the unit is dead.
If the latter, disassemble the case, remove the disk-drive, and attach it as an "internal" hard-drive to your computer.
Nov 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor blocks computer from processing - locks up
disable maxtor before shutting down the PC to narrow down the problem.
Jul 05, 2009 | Computers & Internet
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Computer does not recognise the Maxtor 3200 personal storage
hdd problem,, 50% can fix you hdd.. if you have inportant data just make recover.. you can't use that for install program and operating system just only for external, save data but dangeros also maybe someday it wil not work totaly..
try to change the board if could
Jun 16, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor personal storage 3200 problem!!!
First, try another USB Cable. If that does not work properly then I would suspect the box or the drive has failed. If you just bought it, return it to the store and complain. They may replace it. As for your data?
Now if you want to become techie you can remove the hard drive from the box and attach it to you computer either copy the files back if you do not have them on your computer or format the drive if you have your files. Then put the drive back in the box and try to get a refund or buy a different external. I like a metal box with an AC cord plug. Best of luck.
Jun 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
