My problem is i have an iomega external hard drive and my system is not detecting it
  • 176 Answers
Try a different usb port. try a different computer if that doesnt work.
Posted on Jul 18, 2010
SOURCE: Corrupt External Hard Drive not detected
once for mTTED, YOU CAN USE RECOVERMYFILES TO recover your files from the formatted disk, it should recover all files and then copy them to another drive, you cannot save/copy them to the same drive you are recovering from.
Posted on Oct 06, 2008
  • 69 Answers
SOURCE: WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
Posted on Mar 25, 2009
Crankstart
  • 696 Answers
SOURCE: Is it possible to open my Iomega Prestige 1 TB USB
Yes it is possible but the Iomegas are difficult to open and you often snap the plastic retainers in the process. Given you can buy a !TB comlete for only about $20 more than buying the raw drive I suspect you would be better advised to simply replace the unit all together,
Chris
Posted on Aug 30, 2009
  • 739 Answers
SOURCE: cannot copy files to Iomega 500 GB external hard drive.
It depends on how you formatted the the drive.
If it was formatted FAT it will work on both Mac and PC.
If you formatted to HFS+ (the native mac format) then it will only work on a mac.
Posted on Sep 17, 2009
SOURCE: my iomega 500gb external hard drive has a broken.
My Iomega (33654) 500GB USB isn't working. When I turn it on the blue light comes on for a few seconds. I can hear / feel it working but then the light goes off (it is still whirring inside). The computer isn't recognising it. I think it's still under guarantee but I can't find the paperwork. Do you have any ideas?
Posted on Jun 21, 2010
Where can i find a manual
I couldn't find a manual but maybe asking the proper question about your Iomega Hard Drive someone might get you an anser.
Most common issue is that it is not recognized so here uou have some solutions:
My iomega external hard drive not showing up in my computer but does...
iomega HDD external drive not detected LED comes ON but wont run SOLVED
Windows 7 help and support forum
External Hard Drive Not Showing Up
Aug 13, 2015 | Iomega Computers & Internet
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Mar 07, 2015 | Iomega Corp iomega eGo Helium 1TB 2.5"...
Blinking light on iomega external hard drive
Try plugging the unit into another working computer. If the same thing happens then the external drive is toast. U may be able to remove the drive with within the unit, set it up as a slave, install on working computer and possibly extract any and all needed files before throwing it out.
Nov 22, 2013 | Iomega Prestige 1 TB USB 20 Hard Drive
My Iomega HDD 80 GB not detected and become noisy, so pls help
-it sounds like your external drive had a head crash. The noise is normally grinding noise.
-if your data on the drive is priceless, you may need to consult recovery experts like http://www.drivesaversdatarecovery.com/.
Dec 18, 2010 | Iomega HDD External Desktop (32660) 80 GB...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Nov 05, 2010 | Iomega Silver Series External 250GB...
My seagate hard drive cannot be detected on the desktop anymore. Any ideas what to do? I have a Mac Powerbook G4
am not so sure if this is a similar issue with iomega external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link.
Apr 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Desktop cannot read/detect iomega even though on and connected - what can be done to restore proper interaction between Iomega External Drive and my Desktop?
this is in April...so make sure all connection are connected...go to start/all programs/accessories/system tools/system restore...(you are going restore your pc to an early date when it was working properly)...next...choose March 04, 2010..your system will cut off and restart you must click ok when prompt to do so when booting back up
Apr 04, 2010 | Iomega MiniMax Desktop - Hard drive - 500...
Can not detect on mypc
install the drivers from iomegas website
Jan 16, 2010 | Iomega (33215) 250 GB Hard Drive
I can't access my fiels on my iomega drive, it
Is is getting detected . If not the solution is to try for a new one. the internal chips may be damaged.
Sep 03, 2009 | Iomega HDD External Desktop (32660) 80 GB...
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Computers & Internet Logo
73 people viewed this question
Alun Cox
David Payne
David Payne
