Question about Whirlpool Duet GHW9150P Front Load Washer
F2 shows up when washing - Whirlpool Duet GHW9150P Front Load Washer
  • 1,998 Answers
F/02" Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
hope this helps
Posted on Jul 18, 2010
Testimonial: "We had a glove stuck in the drain hose. Washing machine working well again. Thanks"
Aristhon point f2
F02 - Motor tripped, tachogenerator open circuit or short circuit.
Dado
Aug 16, 2014 | Ariston Technologies Washing Machines
F2 SIGN COMES ON THE I F B MACHINE
F2 Is Usually A Trouble code, consult your manual or Go to manufacturers site for troubleshooting, usually on the help Link,
Good luck.
Apr 08, 2014 | IFB Washing Machines
The top drawer of our F & P dishwasher is showing and F2 fault, I have just fitted a new front control unit. F2 is the pump I believe, where on the unit do I find that?
The F2 fault implies there is a problem with the motor rotor which is located under the drain plate at the bottom right in the centre of the drawer. The rotor is actually driving the wash arms.
F2 does not necessarily mean you have to replace the rotor. It is also possible there is some debris inside the rotor cavity which is preventing the rotor from rotating at the normal speed.
Remove the racks and the wash arm. Twist the centre ring so that it disengages the drain plate. You can then pull the rotor out with a few back and forth twisting motions. Check if the cavity is clean. Re-insert everthing and start the wash cycle. If F2 comes in again, you will have to eliminate the cause by using the rotor from the bottom drawer and see if it makes any difference. You may then have to buy a replacement part.
good luck
May 26, 2011 | Fisher and Paykel 23 in. DD603H SS...
We have the error F2 showing on our dish drawers
normally the F2 showing on both drawers is unusual.
It is a rotor fault. Which means either the rotor that drives the wash arm and also works as a pump is either faulty or there is some rubbish stuck in the rotor cavity.
Lift the fiter plate out and open the rotor ring. Get the rotor out and inspect. If it looks ok or there was no noise when the F2 error showed up then the hall sensor mounted on the underside of the drawer is faulty.
The hall sensor can be hard to replace unless one has good experience in repairing dishwasher.
Nov 27, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE 4T
HE 4 front load remove bottom panel 3 screws once remove now you have access to pump get towels and bucket oper lint filter and remove debris from inside ,,,,, and that its F2 long drain,,,,,,
Oct 13, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
F2 code
go back to drain pump.. pull pump out ckd the impeller on motor pump shaft there should be a slight resistance when the impeller is turned by hand ..have seen impeller come loose of motor shaft and free wheel
Aug 27, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
56 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
