Question about Mitsubishi WD-Y57 57" Projection HDTV
Air flow on the screen will say TV will shut down in a few seconds - check to see if air flow is blocked
  • barrenj Jul 01, 2008
    I have a 2006 Mitsubishi 57"dlp unit. I get the air flow error on the screen the in 15 sec the unit shuts down. When I restart it in10 or 15 min same thing happens.The manual has nothing on this.I've used a fan to no avail. This does not happen all the time, it can run for hours with no problem.
Call Mitsubishi. They have extended their warranties on certain DLP's, because of a faulty thermal sensor. I just had mine fixed at no cost by an authorized service provider.
Posted on Nov 12, 2008
PUT A LITLE FAN THAT COULD HELP
Posted on Oct 20, 2008
I just had this problem happen to me, tonight. Did you have any solutions that worked ?
Posted on Jul 15, 2008
    Genius:
  • 1,030 Answers
This is commopn problem. i have seen were the thermal sensor needs replaced
Posted on Apr 21, 2008
TV will shut down in a few seconds. Please check if the air flow is blocked, and then the TV shuts off.
We had that problem for the first year we had the TV. When looking for a new bulb I had found on the mitsubishi site that there was a problem with the sensor and for a certain amount of time they would fix it. Of course we were beyond that time, but hubby was able to do something where we split the cost. No problem since and haven't vacuumed it once. It has been at least a couple years now.
Sep 04, 2011 | Mitsubishi WD-57732 Projection Television
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Area around TV is clear, nothing is blocking TV or air flow. When we use the TV we frequently get this message: The TV will shut off in one minute. Check to see if air flow is blocked. Happening more...
you need a new power supply unit these after some time get old and start over heating causing the tv to heat up intermediately if you take it to a repair shop and have that replaced it will be like new again
Feb 25, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Air flow is blocked
In the 65" TVS there are 4 or more fans One of these is not functioning Probably the one over the power supply itself This will cause it to heat very quickly and shut down in a matter of about 20 seconds.
only way to find out which fan is not working isw to remove the back.
please rate my help++++Thanks for using FIXYA
May 08, 2010 | Mitsubishi WD-65731 65" HDTV
TV shuts down due to air flow being blocked
They had some stupid problems with these sets---If you know how to remove the lamp---it is customer replaceable--take it out and examine it. Shut set off first and wait a few minutes for the lamp fan to turn off. Unplug set and locate and remove lamp. Some of these sets had a lamp (it is in a cartridge like a box) that they covered openings on the housing with a screen like material (like window screen). One side of the lamp has a fairly small narrow strip of this and it blocks up with dust from the fan which is trying to keep it cool---if the screen is blocked up you will see it; Do not touch the face of the lamp when you handle it--if you find yours has a screen like material--clean it off with a brush and put it back--the later replacement version of this lamp has a screen that is coarse and does not block up with dust---on a couple of these I removed the blocked up screen material until I could get the newer lamp so the customer could continue to use it--if cleaning the dirt off works you may have to do it from time to time--depends on environment--the fan tends to pull dust and such out of the air and right into the lamp---
I do this for free here so if this does help you give me a vote here. If you have questions or need help contact me here.
Aug 28, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
Airflow blocked tv will shut down after a few seconds
Good Day;
If you have a WD-52525 Model TV and the the screen displays "air flow problem" change the sensor. There's not a positive way to check device, just replace it, trust me. IF your TV is a different Model MIT'S has a recall on those certain Models. REPLACE.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
Mitsubishi WD-Y57 57" Projection HDTV Logo
597 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
