Question about Black & Decker PHS550B Powered Handsaw withStorage Bag
I am unable to get he blade in the b&d powered Handsaw. I know it has somthing to do with the sid ebutton but for th elife of me I cna make it attach
How do I change the blade on the black & decker powered handsaw PHS550 type 2
Go to http://www.manualowl.com/m/Black%20%26%20Decker/PHS550B/Manual/412144?page=2. Follow instructions.
Oct 05, 2014 | Saws
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
Holes for sub power cable from battery to cabin
Where th main harness goes into the cab there is a rubber gromet. Cut a **** in the gromet and sid through there be carful and donr cut the harness
Jan 21, 2013 | Car Audio & Video
I have an old Sears Craftsman 7" Electric Handsaw model #315.27782. The blade I use for fine sawing has begun to wobble. I've taken it off, put it back on and tightened it several times. Same wobble. ...
It could be that the bearings that support the shaft that holds the blade are worn, allowing the shaft to move slightly and make the blade wobble. As the machine is an older model, I would try replacing the bearings.
Sep 16, 2010 | Craftsman Saws
We can't get the blade to go in
There should be a button on the right side of the saw to press in to open the clamp for the blade.
Blade changes require no tools. There will be a pin that engages the hole in the blades.
May 09, 2010 | Black & Decker PHS550B Powered Handsaw...
Are sid and radio code matched for 900s 96 conv?
no.
sid cna be changed when ever.. radio code can be retrieve by dealer for free just call... you will need to take out the radio it self to see the PUI number
Sep 26, 2009 | 1994 Saab 900
How do you install the blade in the craftsman recipricating saw model 320
You need a allen wrench to remove the blade and to reinsall it look at the base of the blade and you will see an allen wrench. If there is no allen wrench then you must pull down on the clap assembly to release the blade. If you still can't figure it out here is sears web site where you can get help for it if you need a picuter.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26128394&sid=PSx20071217x00001a
Sep 17, 2009 | Craftsman 8.0 amp Reciprocating Saw
Black & Decker PHS550B Powered Handsaw withStorage Bag Logo
755 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Frank Mangiapane
Level 1 Expert
Mike
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
