Question about Dyson DC14 All floors Bagless Upright Cyclonic Vacuum
Wont **** the beater brush works but it's not sucking stuff into the canister
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
Sounds like a blockage some where take apart the hoese and clean them one at a time
Posted on Jul 28, 2010
Vacuum brushes are turning but not picking up dirt and is blowing a lot of air out of the top air filter thing
Did you check carefully for splits? After sucking something up that big, you may have split something, like in a fold of the hose. When it is in a position where the split is somewhat sealed, it works. Move it just a bit and the split separates and it won't work.
Mar 29, 2014 | Vacuums
The suction is quite poor, also definite burning smell after normal use. we only have about 3 years would it be the engine
I would check the drive belts for the beater brush and make sure the beater brush itself is free to move in the holders. Clean the beater brush of all debris and add a bit of WD40 on the two ends between the brush and the holders.
I do not charge for my advice. : )
Paul
Sep 18, 2010 | Hoover S3755 WindTunnel Bagless Canister...
I have a Sears Kenmore canister sweeper with the power mate, but it no longer has sufficient suction to pick up dirt. I took the machine apart and cleaned it, but it is still not sucking, does this model...
When cleaning the machine, did you do a good job of cleaning the beater brush and making sure it turned freely in the holders on each end? Perhaps a bit of WD40? Also, a new set of belts might help a bit.
Sep 18, 2010 | Kenmore 22812 Bagged Canister Vacuum
The belt keeps breaking. Like it's burning through.
Sounds like the beater brush the belt is supposed to turn has frozen up due to debris. Remove the brush and clean all debris. At the ends of the brush will be two fasteners that hold the brush in place, be sure all debris is cleaned from these and add a small amount of WD40 where the beater brush fits into these two small holders. Turn the beater brush around these holders by hand to be sure it moves freely. Reassemble with new belt.
Sep 17, 2010 | Dirt Devil Breeze Canister M082550 Bagless...
Dyson ball not picking up properly and very noisy
Is the beater brush spinning? Is the sole plate that is removable and covers the bottom side of the beater brush housing installed properly such that there are no gaps between it and the housing? Is the hose that connects the beater brush housing to the canister connected or have any holes in it?
May 26, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Unit powers up but beater bar does not rotate
Have you checked the belt that drives the beater bar?
Oct 01, 2009 | Kenmore 22812 Bagged Canister Vacuum
Brush does not turn on my vaccum
If there is no suction when you disconnect the beater bar assembly near the hand hold where you grab the vacuum, then there may be either a restriction in the vacuum line between there and the vacuum section (that rolls around behind you), or the vacuum line from the handle point to the rollaround section is not properly connected. This all assumes the vacuum motor in the rollaround is running.
The beater bar section does nothing but cause dirt particles to be sucked into the vacuum system. The vacuum or suction is created in the rollaround unit.
Jan 22, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Bad bearing on kenmore whisperbelt beater brush.
Sorry,
I thought this was a free forum. I do not intend to hire a bunch of experts to find out if a bearing can be found for my vacuum cleaner when the entire brush assembly in $39.99.
This is a very tricky way to get unsuspecting people sucked into paying for something they thought was free.
Bad business, sorry.
Dec 30, 2008 | Kenmore 22822 Canister Vacuum
Power brush not working well
You probably have a worn belt that drives the beater bar... 2 year old belts with reasonable use are more than likely due for a replacement. You should be able to get a replacement drive belt from Sears and change it yourself.. The baseplate of your power brush seperates and should provide access to the beater brush and drive pulley system.. Hope that helps..
Aug 25, 2008 | Kenmore 22812 Bagged Canister Vacuum
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Dyson DC14 All floors Bagless Upright Cyclonic Vacuum Logo
41 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
