Question about RTO Decolav Push Button Closing Umbrella Drain with Overflow 1.25" 9297-CP
Button is stuck in down position how can I release it to make it drain? decolav push drain approx 3 years ols stainless steel in raised sink bowl.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: We have either the 9297
By turning the top part (umbrella) CCW you should be able to spin it out and see if the threads stripped or if there is something bent. You also can checkout the spring and make sure it is working and is not bad also.
heatman101
Posted on Apr 19, 2011
How good are Kraus kitchen sinks?
Kraus KHU100 Kitchen Sink
A kitchen sink is not an optional part of your kitchen. Therefore, people pick a sink that suits well with their kitchen styles and functions properly with enough durability. It must be a tough job for you to search for a sink that has all these features in it.But you do not have to bother anymore as we brought here a Kraus KHU100 Kitchen Sink review to you. The review reveals about wonderful features and specification of Kraus stainless steel kitchen sinks.
Kraus Undermount sink is a heavy-duty handcrafted kitchen sink with a sleek style. It goes with your traditional or modern kitchens perfectly. You might know that Kraus stainless steel sinks are loved by the customers for their quality and longevity. Consequently, Kraus single bowl stainless steel kitchen sink is well-liked by many because of premium-grade thick steel and outstanding quality.
Kraus Undermount kitchen sink has a lot more impressive traits that would make your choice clearer in buying this efficient sink.
Overview
You might have faced hassles in managing to clean your large and huge utensils in a sink. But Kraus stainless steel kitchen sinks figures out this issue. Kraus stainless steel sinks have a deep and spacious sink to accommodate your enormous kitchenware.
Kraus stainless steel kitchen sinks are engineered for optimal drainage with channel grooves that prevent water pooling in the middle of the basin. Besides its features, the Kraus KHU100 Kitchen Sink review holds the technical specifications of Kraus single bowl stainless steel kitchen sink too.
Specifications
  • Item weight: 26 pounds
  • Product dimensions: 32×19×10 inches
  • Size: 32 inches
  • Color: Stainless steel
  • Style: Sink
  • Sink Shape: Rectangle
  • Finish: Satin
  • Material: 16 gauge Stainless steel
  • Installation Method: Undermount
  • Bowl type: Single bowl sink handmade
  • Basin depth: 5-11 inches
  • Bowl depth: 9 inches or more
  • Technology: Noise Defend
  • Number of Basins: Single
  • Minimum cabinet size: 36 inches
  • UPS Approved: Yes
  • Nose insulation: Yes
  • Warranty Description: Limited lifetime
Mar 18, 2018 | Home
Which is the best kitchen sink model?
Ruvati RVH8300 Kitchen Sink Overview
Ruvati kitchen sink gives you a chef-like experience. There is an overhanging lips on the front and back that provides a track for your cutting board and colander. The ruvati rvh8300 is constructed with 16 gauge premium 304 grade stainless steel and has a satin finish. This provides your kitchen an elegant look that lasts quite a long time.
The overview section of Ruvati RVH8300 kitchen sink Review basically talks about the technical specifications of ruvati sinks. These specifications are equally significant to judge any product before buying it.
Specifications
  • Series: Roma
  • Brand: Ruvati
  • Item weight: 50 pounds
  • Product dimensions: 19×32×10 inches
  • Style: Workstation
  • Finish: Stainless-steel
  • Material: Stainless Steel
  • Shape: Rectangular
  • Thickness: 16 ga
  • Installation method: Undermount
  • Item package quantity: 1
  • Number of basins: 1
  • Number of bowl: Single bowl
  • Drain placement: Center Rear
  • Texture: Satin
  • Assembly: Assembled
  • Certification: Not applicable
  • Special features: Workstation
  • Warranty description: Lifetime
Mar 15, 2018 | Home
Rear drivers side seat is stuck down on my Mercedes 2004 ml350, how can I get it to release and come up
The best thing to do take the entire back seat out then find the problem and fix it. also check in manual guide it could be anything from spring and anything else, if you have to press a button to raise the seat up and down first check the manual guide then check the fuse.
Mar 01, 2015 | Mercedes M-class Ml Ml350 Ml500 Ml55...
I have a glass bowl sink in my bathroom. The pop-up drain is stuck in the down position and will not release. How do I fix it??
You'll need to access back side of sink bowl and locate drain mechanism, most likely either the plunger rod has loosened up from clevis rod or clevis rod is positioned to far in towards drain line causing it to bind. Check diagram for assistance in locating parts.
Is the plunger rod tight or loose? You can also loosen clevis screw and see if the plunger rod will slide freely. If it does try moving the horizontal pivot rod up and down, while doing this you should she your drain plunger moving up and down. If it does not then most likely will need to replace plunger mechanism by removing the retaining nut on the back side of the drain line. This will allow you to disassemble the actual drain plunger but I would definitely start with the mechanism of the stopper and clevis where it attaches to horizontal rod.
Sounds like a simple binding. Always be sure there isn't anything stored under your sink which could be causing the problem. Sometimes the most obvious is the last thing we look at.
Good luck.
Aug 16, 2013 | Pegasus Technologies Pegasus Clear Round...
I have the Decolav 1201 SS sink under-mounted to my granite counter. It appears that I need a special drain as none of the ones I saw available are for sinks that are the thickness of stainless steel...
Did you add the rubber gaskets so they are on the underside of the sink? If they are on the underside of the sink, then I think you're modification is a good one, and I'm not sure the gaskets are the cause of slow drain. Not sure what would cause the last inch to drain slowly. Now, if the gaskets are inside the sink bowl (i.e. visible from above) and the drain tube is elevated up from the base of the sink bowl, then there's is a likely source for the problem...
Regards,
DIYpro
Jun 07, 2011 | Deco Lav DecoLav 1201 Simply Stainless...
Drain won't close
hi, the button can come out of the drain hole either by unscrewing it or some simply pull out, once it is out there is a threaded bolt attatched to it this can be adjusted by screwing it in or out
Jul 06, 2010 | Deco Lav DECOLAV Decobronze Push Button...
Where can I find parts (seals) for the decolav push button drain?
Take it to a auto supply and have them match the "O" ring. Or try a bearing and seal supply (specialty) if auto parts supply store doesn't have it
Jul 03, 2009 | Deco Lav DECOLAV Decobronze Push Button...
Rust around the drain in the larger of the two sinks
You will need to reset the basket strainer using plumbers putty. Is there a garbage disposal installed? You will need to remove it to get to the basket strainer.
Mar 31, 2009 | Franke VNX-120-45 Vision Double Bowl...
Odor from Decolav bottle trap
there really should be a trap with a bend in it on the system at somepoint to prevent odour ingress?
Nov 22, 2008 | Deco Lav DECOLAV Chrome Polished Grid...
Stainless Steel Sink Question
s with most things, your stainless steel sink WILL scratch with use. However, over time as the sink ages, scratches will become less apparent and in fact blend into the surface. Minor scratches on the inside surfaces of the bowl may be blended into the sink by lightly rubbing a Scotchbrite pad in the direction of the finish grain. Be sure to rinse thoroughly with water and towel dry after this procedure, removing any particles left over from the Scotchbrite as you rinse.
Aug 27, 2008 | Advance Tabco Stainless 3 Compartment...
RTO Decolav Push Button Closing Umbrella Drain with Overflow 1.25" 9297-CP Logo
1,709 people viewed this question
Top RTO Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a RTO Plumbing Expert? Answer questions, earn points and help others
