Question about Samsung AW1203B Air Conditioner
Amana air conditioning unit
My air conditioning blowing weak. i have to push the fan for it to start.
  • 6,927 Answers
You either have a blower that is gone out,or the start capacitor is bad,it is most likely the blower motor.
Posted on Jul 18, 2010
Ac repair portable 12000 btu unit will not blow cold air
Maybe you have it set on dehumidifier mode instead of air conditioning mode. That happened to me with mine too. And turn off your timer (if it has one) or it will shut off after a while and you will forget why.
Jul 23, 2013 | Amana Portable Air Conditioner
Amana PTAC PTH094E35 fan motors seem periodically unable to get fan turning. Have to sometimes remove the cover and manually spin the fan to get it going.
Check capacitor to be sure it's not weak also if after you push start the fan, if it has a chirping sound, it may have a bearing issue in the motor. Note if you are cleaning the units with a pressure cleaner be extra careful so you do NOT get the motors wet due to some of the smaller motors used in A/C units are moisture sensitive
Mar 20, 2013 | Amana PTH094E35 Air Conditioner
My amana window ac is blowing condesation out the vents. it is still cooling..is this a problem
There is a condensation drain on the unit that is probably plugged. It is natural for air conditioning units to produce condensation as the evaporator coil (the coil/fins that make the air cold as a fan blows air across it ) is much colder than the outside air temperature ( usually between 38 and 55 degrees depending on the unit ). There is a basin or tray at the bottom of the unit that catches the condensation as it drips off the evaporator coil, and there is a drain that allows the water to drain form the unit. If this becomes plugged the water will build up and eventually drip out of the vents of the unit. http://www.air-conditioning-and-refrigeration-guide.com/air-conditioning-circuit-and-cycle-diagram.html
In the image, air is blown across the coil in the bottom left section of the picture ( this is the "cold' coil). Condensation can form on this.
Jul 29, 2011 | Amana Quiet Zone 12M12TA Air Conditioner
Central air conditioning unit blows air but not cold air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 29, 2010 | Amana Heating & Cooling
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Oct 20, 2009 | Amana PTH153B50AE Air Conditioner
Blower motor not blowing
you will have to replace the blower motor
Aug 11, 2009 | Amana PTH123B35AE Air Conditioner
A/C blows weak/low volume of air through vents
I f it is fan that has more then one speed if you run it all the time,it may
not be on high sample : low fan speed runs all the time
med fan speed for heat
high fan speed is usually for air conditioning so if everything is good then it maybe the relay.
May 02, 2009 | Carrier Heating & Cooling
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Samsung AW1203B Air Conditioner Logo
87 people viewed this question
Top Samsung Heating & Cooling Experts
gbob59
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
