Question about Kitchen Ranges
I was defrosting my freezer and accidently punched a hole in the freon. It leaked out. Can I turn the refrigerator back on or is it dangerous? Can the hole be fixed?
  • mesa_diva Jul 18, 2010
    Thank you. It looks like I will need a new frig.
    Brigadier General:
  • 4,044 Answers
If you turn the unit back on it's not going to cool and will burn the compressor out. It is possible that the line could be repaired but even after have teh line repaired a dryer would have to be installed, the lines would have to be vacumed and charged with the correct Freon. Refrigerators and freezers do not use the same freon that is used in Vehicles.
Posted on Jul 18, 2010
Refrigerator clicking not cooling
If your refrigerator cooling doesn't seem to be working well, and you have no idea what to look for in troubleshooting your problem, there are some things you can do to try to figure out your problem without paying a serviceman to come into your home.
Freezing
Most new refrigerators come with automatic defrosters. Although this is a standard feature the drain hole in the defrosting assembly can get clogged with debris, lime, or even ice. If this happens the defrost will not work and there will be a build-up of ice in your freezer that begins to block the freon from flowing properly and causing heat to react improperly and cause your refrigerator to stop cooling.
Freon
Freon systems in a refrigerator are closed systems but on occasion you may need a recharge. Refrigerators use R-134a freon, just like in an automobile. The old R-12 freon is no longer available, so if you have an older model of refrigerator you will not be able to obtain the freon, and it will be recommended that you replace that refrigerator.
Seals
The seals that are on the door of the refrigerator and freezer can dry rot with time. When you begin to see the seals cracking or warping, if your refrigerator opens more easily than before, or if you see the the door does not close fully without pushing on the door then the gaskets around the doors will need to be replaced. They are held in place by clips and the replacement is an easy fix.
Holes in Lines
Let's face it, many people find ice in their freezer or the back of their refrigerator and will try some self-help without knowledge. They will grab a knife or fork and start chipping away at the ice. This is extremely dangerous. There is a great risk of puncturing a hole in the freon lines by stabbing at the ice. Since freon has the purpose of cooling most ice collects the thickest on the inside of the walls with the freon lines right behind the plastics. A better method of removing the ice is to empty your refrigerator, turn it off and leave the door open. If you want to speed up the process you can turn on a blow dryer and aim it at the edges of the ice. If you aim at the edges you will warm up the ice and create warm water which will flow down and help to separate the ice panel from the wall.
Uneven Refrigerator
If a refrigerator is not even on the floor it may not close properly. Rock your refrigerator and see if it seems to topple from one foot to another. The feet on a refrigerator can be adjusted by screwing in or out and leveling each foot individually until they are all even.
Non-Problem Warming
If your home is hot your refrigerator will work harder. If you put a lot of food in your refrigerator and freezer, your coolant will have to work harder, and it will seem to take longer to cool. It is just that there is a lot of food that is trying to freeze or maintain cool temperatures.
Hoping this will help in solving the problem...
Aug 04, 2011 | Refrigerators
Not cooling
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Hope this helpout...
Jul 06, 2011 | Kenmore Side by Side Refrigerator
Not cooling, but seems like everything is on
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Hope this helpout....
Jul 03, 2011 | Maytag Refrigerators
Freezer isn't cold, defrosted all of my food and the refrigerator part doesn't seem very cold either.
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Good luck
May 31, 2011 | KitchenAid KSRK25FVMK Stainless Steel Side...
Refridgerator does not get cold, maybe needs freon charge or coooland recharge
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Good luck and Thanks
May 13, 2011 | Haier Refrigerators
Maytag MTF2155GRW Refrigerator Both freezer and refrigerator are not cold. Fans are blowing warm air in both freezer and refrigerator. Any ideas what is wrong?
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Hope this will help in solving the problem......
May 08, 2011 | Maytag MTF2155GRW Top Freezer Refrigerator
My freezer is not keeping my food frozen, even at highest setting...what could be the reasons why?
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Hope this helpout.......
Aug 13, 2010 | Refrigerators
Refreg not cooling
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Aug 02, 2010 | Kenmore 53642 / 53644 Side by Side...
#56548 not staying cold
Freezing
Freon
Seals
Holes in Lines
Uneven Refrigerator
Non-Problem Warming
Hope this will help.....
Jul 30, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
I punched a hole in the freezer what can I do to make it work again
If you poked a hole in the cooling tube and the freon came out, you'll have to call a qualified tech to repair the hole and recharge the system.
If it's just a hole in the wall or something you can just plug it up with anything to prevent air leaking.
Jun 13, 2010 | LG GC-051SS Compact Refrigerator
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
