Question about HTC S620 Smartphone
Stand by time is about 12 hours
Help. my standby time is about 12 hours. i don't know what seems to be the problem.
    Novelist:
  • 142 Answers
Couple possibilities:
1. Old battery: After a couple years of use, the battery simply can't hold a charge as well as it used to. If you are using an old battery, try getting a replacement.
2. Replaced battery with a NON-Brand name: If you replace the battery with a lesser expensive pack from china, they will typically use an inferior set of cells. Use only the name brand batteries for best performance.
3. You're in a location where you cannot pick up a DIGITAL signal. If you are roaming or unable to pick up a digital signal, the cell phone will constantly be searching for a tower wasting precious energy. For best standby times, make sure you are receiving a digital signal.
4. Battery charger malfunction: If you're accustomed to charging your battery with a wall charger, try charging it from your cigarette lighter in your car or with a different charger. If it works longer after doing this, drain the battery and charge again the way you usually do. If you're back down to only 12 hour stand-by, the usual charger may be malfunctioning.
5. Make sure your backlight is not on all the time. If your phone has a setting to keep the backlight on, turn it off.
Good Luck.
Posted on Apr 21, 2008
I have a Emerson 32" LC 320 EM1F, When I press power button, green light flashes 12 times then red light comes on and goes to standby. What seems to be the problem? How can I fix it?
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
Jan 25, 2013 | Emerson Lc320em1f TV
Nec pxt-42sx1b won't turn on. We press the on button on the remote and the stand by light turns from red to blue but then goes back to standby.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.3_26_2012_10_39_22_pm.jpg
Mar 26, 2012 | NEC PXT-42SX1B 42 in. Plasma TV
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
Working less than 12 hours
tyr to change ur charge
May 09, 2009 | Nokia Cell Phones
How do I get my Timex WR50M watch out of the 24 hour (military) time and back to a 12 hour clock?
Hold down the adjust button bottom right then press the mode button top left you will notice the a or p that stands for am/pm will disappear & reappear. If you have an a or p on your display then you are out of military time.
Mar 11, 2008 | Timex 1440 Nylon watch
No picture, standby light blinking
MOST LIKELY THE ERROR 3 IS THE 200V LINE TO THE CRT DRIVE IC.IC702. ON THE CRT PC BOARD. IT ALSO COULD HAVE GONE OUT IF YOU HAVE HEAVY USAGE ON THE SET 8-12 HRS A DAY. THE CTR COULD SHOT AND TAKE OUT THE I.C. AS FOR IS IT WORTH FIXING, THEY DON'T MAKE CRT TV'S ANY MORE AND THE NEW SETS SEEM TO HAVE A LOT OF PROBLEMS.
DON..
Dec 23, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Teac cd-x10i
  1. press the standby/on switch off
  2. Press and hold the TIME SET button for more than 3 seconds and release it when "12H" or "24H" appears on the display. press the right and left arrows to select. press TIME SET again.
  3. the hour value blinks use the right and left arrows to select the current hour. press TIME SET gain.
  4. The minute value blinks. using the right and left arrows select minutes.
  5. press TIME SET again and the clock starts.
Dec 11, 2007 | Teac MC-DX22I Shelf System
Power loss
I WOULD CHECK YOUR CHARGER THAT PLUGS INTO THE WALL FOR PROPER VOLTAGE AMD m/A ... IT WILL BE MARKED. YOUR LOCAL CELL STORE WILL CHECK IT FOR YOU
Jun 25, 2007 | Motorola Mobility SLVR L7 Cellular Phone
HTC S620 Smartphone Logo
119 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
