Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Refrigerator Interior Light stopped Working!
Hello! We have a GE Freezer-Top Refrigerator GTR11AAPARWW. Recently the Interior Light stopped working. We tried replacing the bulb but still no go. In the manuals troubleshooting section for this refrigerator it says, "Replace Fuse or Reset the Breaker" if changing the bulb doesn't work. Does anyone know how to do this? I'm at my wits end.
  • 2 more comments
  • SuzenMaria Jul 18, 2010
    I just wanted to add that the refrigerator works just fine, it's only the light the doesn't work. I tested the bulb and it works in the lamp we tested it on.
    Thank you for the information!
  • SuzenMaria Jul 19, 2010
    I purchased a new switch, hopefully that will do the trick! I'll let you know if it works and we have success!
  • SuzenMaria Jul 22, 2010
    I ordered a new light switch, just put it in, and we have lights again in the fridge! Thanks for your help guys.
  • GE Master
  • 3,740 Answers
If you changed the light bulb but the problem persists and the rest of the unit is working fine then the door light switch has probably failed. Item 13 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5131917&diagram_id=24986225#d24986225
detailed view: http://www.appliancepartspros.com/part_details.aspx?part_id=3193221&image=2
This will be located in the fold hinge area of the door.
Note the 2 tabs on the sides that must be depressed with either a putty knife or a kinfe blade to remove it from the chassis. Then it is a matter of disconnecting the 2 terminals. You can test this with a meter using resistance by pulling off one wire and depressing the plunger. Static hands off the plunger you will read continuity. Plunger depressed it will read open. If your switch does NOT read like that then it has failed.
Additionally.... there is the possibility that ice build up in the back of your light socket has disconnected one or the terminals of the socket. The light socket is removable from the front. Most of the light sockets rotate 90 degrees (CAREFULLY with bulb removed) and then can be removed. Check the terminals of the socket to make sure they are attached.
As far as replacing fuse.. or resetting the breaker they are talking about the house main power panel. If everything but the light works the Fuse or Circuit Breaker is NOT your "no light" problem.
Thanks for using FixYa.
Kelly
Posted on Jul 18, 2010
    President:
  • 670 Answers
What the manual states about replacing fuse or reset the breaker is if there is no power to the fridge outlet. It is refering to the home fuse or circuit breaker box, which I assume is working since you are concerned about the interior light of the fridge.
There is a not a whole lot that can go wrong with the interior light. The only components are the bulb, bulb socket, door switch and the wiring. To troubleshoot, verify that you are getting power to your light bulb socket. If you have a meter, remove the bulb from the socket and place the meter leads to the electrical contacts in the light socket, you should be reading 120VAC. If you don't then the problem is with the wiring or the switch. If you do have power in the socket then, verify that the bulb is good by using the meter or installing it into a lamp.
If the bulb is good, but does not work in the fridge, is sometimes the bulb is not installed properly. What I mean is even when the bulb seems to be screwed in and it is tight, that it still does not make an electrical connection. You might need to give the bulb an additional fraction of a turn in order to seat the bulb into the socket. I remember a time when I thought that the bulb was screwed in, it would not light. I needed to give it an other half a turn to get the lightbulb to work.
Hope this helps you.
    Thanks for the info. My landlord is an electrician so I'm sure he has a meter. I'll let you know what happens!
  • Stephen Lam Jul 22, 2010
    I am glad that I was able to help you to solve the problem with your refrigerator. I wonder if you could do me a favor, by accepting my and rating my answer? Thanks so much, it was a pleasure to help you and thank you for chosing Fixya!
  • 760 Answers
The manual says to replace fuse or eset the breaker for the receptacle the refrigerator is plugged into. If it running, and cold that's not the problem.
First test your new bulb in a lamp to be sure it's working. If its the rubber type socket type make sure the bulb is all the way in. Make sure there isn't a broken bulb base left in the socket. (do this with refrig unplugged) Check door switch that it isn't stuck, or "frozen" .
  • Tom W Jul 19, 2010
    Ok, did you see anything inside the socket? And you've checked the switch moves in and out? Try removing the siwtch (with refrigerator unplugged) and disconnect the wires. Put two wires together. Plug the refrigerator back in if it works now the switch is bad. IF this doesn't work, remove the light socket( again with refrigerator unplugged) and notice the connectors that carry voltage to socket. Make sure they are not damaged. Inspect the socket when it is removed. Light switch is about 30.00 and the socket about 12.00. If you have no place for parts you can buy them from www.searspartsdirect.com
3-year old mini freezer/refrigerator has stopped working.
Seems to be compressor not working kindly check your refrigerator thermostat setting or capacitor device worn out
Need to replace
Jul 12, 2016 | Frost Refrigerators
L;ights not working
May be faulty bulb/ blown bulb or issue with light switch itself.
Replacement parts can be purchased at any of the following web sites:
pcappliancerepair.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | GE Refrigerators
I have a GE SSL27RGRB BS. The freezer stopped freezing all the way when I took off the interior rear panel the bottom coils are working good but the top coils are warm and do not freeze at all. What do I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
@15 yr old GE top freezer fridge. Top freezer
check to see if an internal fan is fitted. This may have stopped/ burnt out. if fan is running try 24 hr defrost.
May 15, 2010 | GE GTS22KBP Top Freezer Refrigerator
GE Refrigerator stopped cooling
I had the same problem. Replaced the damper switch and the motherboard. Then noticed the freezer has frosted over behind the panel in the freezer. Defrosted the freezer and all was working again. The same problem came back about 3 months later. This time the problem was diagnosed as the heater has gone bad in the freezer. Now waiting to have this replaced.
Jun 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Ge refriderator 3yrs old stopped working
Need a model # check for power starting at end of power cord where attaches to refrigertor
Sep 13, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Refrigerators Logo
1,624 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
