Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have a intex saltwater system. I just hooked it up and started using it . I set it up and it ran about 2 minutes and the service light came on. I shut it off and tried it again and same problem.
  • Intex Master
  • 8,404 Answers
Contact your pool professional or the place you purchased the device. Ask for direction and possible warranty adjustment BEFORE you fool around with it.
Posted on Jul 31, 2010
Cloudy/green
super shock pool with chlorine it will just maintain
Aug 11, 2013 | Intex Automatic Salt Water System for ...
I do not have my user manual for my intex saltwater system, I bought it and used it last summer. I forget how to set my system and it is beeping like mad right now. I just want to run the filter system to...
Alright I imagine you have it hooked up already if its beeping at you. A couple of things to ensure first. One is a PCV pipe that has a electrical connection going to a T at the top. On that section of PVC pipe there should be an arrow. Ensure that arrow is pointing in the same direction as the stationary PVC pipe that contains the titanium plates. Now Ensure that you r filter pump is Supplying water to your salt water system. So it should be pool to filter pump to salt water system back into the pool. Now in order to program your salt water system you need to lift the screen protector. Press the left (down arrow) until you hear a short beep then press the right button (up arrow) until you hear another short beep. You just unlocked the keys, now you need to set the hours of operation by pressing the up arrow. For 2000gal pool you want to set for 2 hours if it is 68 to 97 degrees out. anything higher run it for 3 hours. For a 4000gal pool you want to run it for 5 hours if its 68-82 degrees. 6 hours from 84-97 degrees and 7 hours if its hotter than that. Once you have the hours set the machine will automatically start (ENSURE THEFILTER PUMP IS ON). You can relock the keypad by press and holding the down arrow button until it beeps then the up arrow button. A green chlorine light should light up within the next 5 minutes, which indicates the saltwater system started the chlorine production.
Jul 24, 2011 | Intex Automatic Salt Water System for ...
Operating instructions
http://www.intexcorp.com.hk/proifv/proifv_dl_client.jsp?source=intexstore
press and hold down arrow till it beeps
press and hold up arrow till it beeps
now use up arrow to select hours to run
now down again till beeps
and then up again till it beeps
wait 2-10 minutes for second green light to come on
Jun 06, 2010 | Intex Automatic Salt Water System for ...
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Intex Krystal Clear Saltwater Water Sanitizing System
Code 93 means the system is in Stand By (Operation Finished) mode. It will start the next cycle in 24 hours and run for the number of hours you have set, Codes are: 88 Stand By (Start Up) 00 Zero Operating Hours 01 Min Operating Hour or (1 Hour Remaining) 02 thru 12 Operating Hours remaining 90 Alarm Code (Low Water Flow/No Flow) 91 Low Salt Level 92 High Salt Level 93 Stand By Mode (Operating Process Finished)
May 30, 2010 | Intex Automatic Salt Water System for ...
88 flashes on display screen
Hold the down arrow till it beeps then hold the up arrow till it beeps When you see double zero then set the # of hours you want it to run with the up and down arrows.
Then you will need to lock it in use the down arrow again and wait for a longer beep then the up again till a long beep.
You are set remeber that it will take about 5 minutes for the chlorine light to come on
you can also go to intex.comm and watch the video or read the manual
Jul 03, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
207 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
