Question about Daewoo Televison & Video
Hi, I'm from Mexico city , My TV model LC3211NT DAYTEC LCD didn't turn on and the status led is turned on in ambar. Normally when the TV is turned on the status led is green and it changes to red when the TV is turned off. This hapened after the electricity in the house has gone after a few moment. What does the ambar led means? Thanks. My hotmail account is oscauto@hotmail.com
  • 11,361 Answers
Amber usually means it is in standby mode, it goes into standby if it does not detect the video signal.
Unplug it for about and hour to let it reset itself first to see if the problem goes away, otherwise it will need to be repaired.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Jul 18, 2010
How can I repair my LGSMART TV?
hi sounds like failed led or leds in the panel, thanks
shaun
Mar 02, 2017 | Televison & Video
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
Turn on TV, sound from program but no picture, just a bright screen. Picture begins to fade. Brand new led TV, was working perfectly fine last night.
Your TV have problem with its T-Con board. T-con board is one which drives the LCD Panel Pixels in rows and columns. As you didn't specified the brand and model number its not possible to give you the exact picture of T con board How its look like. You can find this board On the top center of the tv. Which will be covered with metal case or aluminium foil to avoid external interference. Here i have added a picture of T- Con board which used in Led Tvs.
Nov 04, 2012 | Televison & Video
My philips 42in lcd tv screen went black, I found a faulty slave inverter and replaced it. Now the screen is still black but my blue led comes on when I plug the tv (without turning the tv on) and fl
However it may sound to you the inverter does not affect the TV's ON/OFF status (i.e. the LED at the front) in almost no way except possibly in case of a dead short when the power board may detect it and shut the whole TV off.
You can disconnect the inverter from power and I bet you the TV will continue doing the same as before.
An inverter is nothing more than a voltage transformer - well, with a key for turning on/off and usually another control for selecting another paramenter, which results in brightness (higher avg output voltage and lower avg output voltage, aka DIM).
For more details I'll need to know the model and I can probably help better.
www.coppelltvrepair.com
Sep 06, 2012 | Televison & Video
Sony won't turn on
Please let me know the exact model no. of your TV to accurately diagnose where the fault came from. Also, please check what is the status of the LED at the front panel, does it has a steady, blinking light, if blinking, please count how many times it will flash. Some of the blinking LED denoting an error code.
Jdvillanueva
Dec 15, 2011 | Sharp LC-32SB21U 32 in. LCD TV
Hello, my Mitsubishi XD28U doesnt turn on, it keeps blinking Red and green (in the power led) and ambar in the status. What might that be?
This means that an abnormal condition is present in the machine.
Contact mitsubishi.
if it were just the red and green blinking on the power, then that is the lamp cover not on fully.
anyway check the lamp cover is fuuly in, and check the filter cover and filter
Feb 28, 2011 | Mitsubishi XD280U Projector
My 52 in jvc model lt-52x579 turns on but there is no picture or sound and about two seconds later the led light for the power starts to blink i tried to turn it off but it just keeps on trying to turn on...
Sound like the power supply board has gone out .Unplug the tv for 2 or 3 minutes and plug it in again and try to turn on. Some times they will come on .But It sounds like the PSB is going out .
Feb 14, 2011 | JVC LT-52X579 52 in. LCD TV
My daytec LCD TV model LM37 does not power on.
There is a manual switch on the bottom of the TV. Just flick it on and it should start to work. The switch is well hidden. It had me for a while. I was ready to go back to the store.
May 27, 2010 | Televison & Video
When turns on, tv gets off
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Check to see if you get any DC voltage on the output connectors.
Please post back what you find.
Dec 16, 2009 | Polaroid 4226TLMB 42 in. LCD TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Televison & Video Logo
145 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
