Question about Samsung Office Equipment & Supplies
Fax machine SF555 able to fax out but not able to receive coming messages
Got a new machine! Cheaper.
Posted on Apr 23, 2008
Fax machine is able to receive faxes, but not able to send them. There is a "No Response" message every time I try to send a document.
Hi, i think your fax machine works fine, A "no response" message indicates that the receiver should accept your fax by hitting on the start button (normally its a green button) for you to able to send a fax or if no one in your friends location is receiving it. In this case you might as well set your fax machine to auto receive fax, defends on your fax machine's model. i hope this helps.
Aug 04, 2011 | Office Equipment & Supplies
Fax reception fails
Hello Dear,
The error message 242 appears in HP Photomart C7180, when the remote machine (the fax machine at Fax Sender side), is having problem, and it is trying to receive fax instead of sending. So actually both these machines try to receive the fax at the same time.
On many fax machines it is possible to accediently initiate the fax reception when:
1. The paper is not loaded in the machine
2. Or The paper is not correctly loaded.
You may contact the fax sender to check the above things. There is absolutely no problem with machine at your end.
Thanks
Mar 10, 2010 | HP Photosmart C7180 All-In-One InkJet...
I want to send a fax message using Brother 2820 fax machine, but I don't want the receiver to see my phone number when he receives the fax message print out. Is there any way I can do this?
The FAX machine will print the Tel number that has been programmed in your machine. It does not print on the basis of the caller ID received. So i think if you remove the number programmed in your fax machine
May 23, 2009 | Brother IntelliFax-2820 Laser Fax
Can't receive fax but can send fax
I have a feeling that it is a re-manufactured or compatible cartridge??
There is a fuse that needs to be replaced on this unit. it blows when the cartridge is installed to reset the machine. If the fuse has not been replaced or is defective the machine will not recognize the new unit.
Feb 12, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Not receiving faxes
make sure your answering machine is plugged in to the "EXT" jack on fax machine, and your main line plugged into "line". try setting fax rings to 1 or 2. set your answering machine to 4. your fax should intercept the call and if it hears the fax tone, will receive the fax. if it doesn't hear the fax tone, it should forward the call to your answering m/c.
hth,
razors
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
I can send faxes, but not receive them on Canon Pixma mx310
Do you have the phone you are answering with connected through the fax machine? If you have the machine set in 'tel priority' mode, the machine will not begin receiving a fax until you press 'FAX' and the 'color' or 'black' button. Alternatively, if you have your phone connected to the 'telephone' jack on the machine (next to the 'L' jack), you can press '2' and '5' on the telephone keypad to turn the machine on in fax receive mode.
Oct 15, 2008 | Canon PIXMA MX310 All-In-One Printer
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
UF 585 Fax Machine Message in memory
if its only a few % like 1, 2, or some thing its probably nothin retrievable, you can have a tech come and clear it but if all else is working and the mssage in mem file dosent keep growing try and ignore it till next service
May 05, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
I have the intellifax 885-mc
Scroll through the menus and look for MANUAL RECEIVE setting. If you get a fax, you'll have to press start.
Apr 10, 2008 | Brother IntelliFAX 885MC Plain Paper...
How to set Ans/Fax receiving mode of SCX-4521F?
Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
Jan 24, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
