Question about PowerBright Power Bright PW3500-12 12 Volt Power Inverter
What size Battery should i use to power my Power Bright 3500W inverter
    Scholar:
  • 142 Answers
If you want to use it on full load for 1 hour - 300 Ah.
If you want to use it on full load for 2 hours - 600 Ah.
If you want to use it on half load for 1 hour - 150 Ah.
And so on.
Posted on Jul 18, 2010
I have a 1000w eliminator inverter and its only putting out 100w. what do you think?
Hi....if you should be needing a 3000W inverter. No way you should use a 3000 watt inverter. Using an oversized inverter will needlessly draw power from the battery. Be aware that 100 watts of power used is 1 amp of battery power used. You have not said what size battery you have but most likely I am going to guess either a group 24 or 27, which means you only have 40-45 amps of battery power that you can use before you start damaging your battery.
Jan 10, 2018 | Inverter Electronics - Others
Greenlight but no ac out
voltage regulator is bad. Most likey bad caps.
May 16, 2013 | PowerBright Power Bright 2300 Watt Power...
Can I plug a camera, shaver, or cordless tool battery charger into this Modified sine wave
Yes you can and no it won't harm it unless something is wrong with it or the charger.
The inverter output doesn't get to the battery, just the chargers output.
Aug 26, 2012 | PowerBright Power Bright 2300 Watt Power...
Hi. I plugged a 600w oven grill and a kettle which is 110w into a 1000w Ring power 1024 inverter 24v-240. And now it dont seem to work. The inverter is wired straight to the battery.
Does it work if you plug in just your smallest appliance 110W?. How about just your 600W appliance What size wire are you using to supply power to the inverter? The inverter will draw about 30 amps from the battery with your load. You need to use wires as large as a number 8 from the battery to the inverter. The length should be as short as possible but could be 20 ft away. My inverter is a 2000 Watt continous and I use welding cable size 0 at about 3ft max between the battery and the inverter.
Jan 29, 2012 | Electronics - Others
My inverter keeps going to falt even though i only use it for a few seconds its only a few months old and has not been used mush its a 1000 2000 max
What are you trying to power with the inverter? Do you know how many watts your appliance need to run? Your 1000 watt inverter needs 83 amps from your battery to drive a 1000 Watt appliance. The minimum size wire you need to hook up the battery to the inverter is a size 6 as short as possible but no more than 25 ft.
Jul 28, 2011 | Inverter 1000-2000w Peak Surge Power
I buy a new power inverter ERP 2300 12v/220Volts
What does the inverter over 600 Watt.
By what type of battery is the inverter supplied? How many Ah? What is its state?
In order to achieve 1000 Watt for 1 hour you need a fully charged 12 V / 100 Ah lead-acid battery.
If your battery is less then 100 Ah and is not very well charged or old (bad) you may not have over 600 W, but not bacause of the inverter, but the battery.
If your inverter stops due to low input voltage (you can see it in the digital display during operation).
If you want to check the real output power of the inverter you should connect it to a big (more than 200 Ah) well charged battery.
Jul 22, 2010 | PowerBright Power Bright ERP2300-12...
Power jack 3500w inverter power problems.
It's complete garbage design. See here:
http://ludens.cl/Electron/chinverter/chinverter.html
Aug 10, 2009 | Statpower PW-1750 Triple Outlet 1750 Watt...
Hp laptop 9720us screen wont brighten or dim. last week my screen went blank brought it to a shop they changed the inverter and also some cable connection . works fine just not quite as bright as before ....
You got the wrong inverter fitted - i'm sure your unit requires a sinle lamp inverter and they have cheated - putting in a generic lamp inverter and branching togeather the wires to accomodate the single plug thus reducing the available volatage for the lamps - this is why it's dim - correct part is 431391-001 Display panel power inverter - For use with single lamp display panel
Mar 10, 2009 | HP Pavilion DV9720US Notebook
Using a 12 to 110 inverter to power it
Check that the power adapter for your laptop supports 110V.
Measure the output power with a multimeter. If its below 110VAC (Alternating Current) your not getting enough power.
Does your computer work when its is not plugged in the Inverter?
Aug 25, 2008 | HP Pavilion dv6000z Notebook
PowerBright Power Bright PW3500-12 12 Volt Power Inverter Logo
156 people viewed this question
Top PowerBright Electronics - Others Experts
Jay Finke
Jay Finke
ray gallant
Are you a PowerBright Electronics - Other Expert? Answer questions, earn points and help others
