Question about KitchenAid Artisan
Hi I have the KitchenAid Artisan coffee machine at home. The steam wand works and when I turn it on, a lot of steam comes out however after about 5 seconds, the amount of steam coming out lessens and there is not enough steam coming out to froth milk. Also both gauges steam up....what can I do?
4 Suggested Answers
z34aga
  • 137 Answers
SOURCE: my kitchenaid artisan coffee machine not enough water
if you have water out brewing without handle with coffee, than you check this 3 things:
  1. how fine is grinded the coffe, is it too fine for your machine?
  2. does pump make enough pressure to brew your coffee(you can measure if you attach an gauge to handle or steam pipe.
  3. by any chance your boiler security valve opens too soon and dont let pump to get the needed pressure. (perfect pressure is from 7 to 9 bar)
Posted on Apr 01, 2009
  • 906 Answers
SOURCE: kitchenaid artisan coffee machine - steam wand
good day,
hope this link below will solve your problem..
kitchen
Posted on Aug 04, 2010
Strattrpt
  • 159 Answers
SOURCE: Hi, I bought my kitchenaid
there is an art to working a foamer ... hence the "artisan" in the coffee-maker's name. There are several aspects to a good foam:
1. If you have been using regular milk to make your foam, try half-and-half ... the thicker consistency will give you a different result.
2. If you have been jamming the foamer head all the way to the bottom of the milk while you are foaming it, try submerging less of the foamer ... this will cause the steam to have a slightly different effect on the milk. If you have been submerging it only about half way (or not at all) try different depths. If one consistent depth is not right, try swirling it around while you foam the milk.
3. Try a different amount of steam (if your steam release valve is adjustable). Pushing a lot of pressure into the milk will give you a different result than barely turning it on.
4. Are you using a cold container or a warm one to hold the milk you are steaming? If you are still not getting the results you are looking for by playing with the other aspects of your foaming process ... try a different container (it sounds silly, but it can really help).
Before you go out and spend a bunch of money on different replacement parts for your machine, spend a while playing with these aspects of your foaming process. If none of these ideas help, then you should consider replacing pieces. Foaming milk is not as easy as it sounds ... it took me a few months of (once daily) use to really get my technique down so I could make a reliably decent foam. Don't give up! and good luck!
Posted on Jun 01, 2011
I have a brand new Kitchenaid Artisan, which works perfectly apart from one thing; it doesn't appear to output hot water probably. It does output steam and a lot of it, which eventually will turn into...
If it is a 5KES100 model then yes that's how you do it, you get your hot water from the steam boiler so the steam needs to be released before the water can come through. Turn the tap wide open and press and hold the steamer pump button. The rush of steam on full open is short lived.
Oct 16, 2013 | KitchenAid Coffee Makers & Espresso...
I left my Artisan espresso machine on between brewing coffee and making hot milk and got an electrical burning smell. Should the machine be switched off if not in use for quarter of an hour or so?
Always off when not being used, it only takes 4 minutes to heat from cold and that can be while you are sorting coffee and cups. Get the electrical smell investigated, these have a problem with seals in the steam boiler which causes switch problems from the steam.
Dec 25, 2012 | KitchenAid Artisan
Kitchenaid espresso machine tripping switches
Relay will be fine if you fix the real problem. Get some new seals (5 of them) into the steam boiler and check for leaks from the teflon tube at the top of the steam boiler. When you have it apart tip it upside down, you will be surprised how much hidden water there is.
May 21, 2012 | KitchenAid Artisan
Hi, I bought my kitchenaid artisan coffee machine on ebay. I can't get the steaming of the milk right. It froths too much so can't make just a latte or flat white. It looks to me that the nozzle...
Jun 01, 2011 | KitchenAid Artisan
Hi, got Kitchen Aid Artisan Espresso Machine. 5y old. Machine just started to brew coffee way to fast. Too much water coming too fast. Normal amount of coffee ready in 5 sec instead of 15-20.... Is this a...
Hi all, got a Artisan 5KPES100 and I'm not getting any water thru' the espresso boiler. Machine is making an occasional noise & sometimes just releasing a bit of steam thru' the espresso boiler, but no water. Have replaced the water pump, but still no water being drawn from the water tank. Hose is NOT kinked & there IS sufficient water in tank. Could it be the solenoid? Can I swap over the solenoids(coils) to check as frothing boiler is still producing water & steam? Any ideas would be magic.
Apr 13, 2011 | KitchenAid Artisan
I am contemplating buying this machine but i have just read many negativerreview on coffee snobs forum. Mainly issue with the steam boiler, guages and declining steam pressure over time. Any advice welcome...
The steam guage is rather slow to respond and the pointer has become detatched on my machine but it's working well and froths good after about 5 minutes from start up, although I do tend to leave my machine on all day and just make sure that there is sufficient fresh water in the tank
Dec 27, 2010 | KitchenAid Artisan
Only hot water comes out of the steam wand
Hi
Sounds like you might need a new steam boiler, or you may have a fuse that is blown for the steam boiler.
Oct 06, 2009 | Saeco Vienna Digital Coffee Maker,...
My kitchenaid artisan coffee machine not enough water
Mar 31, 2009 | KitchenAid Artisan
Krups 867 boiler steam leak
Save yourself the trouble, buy a $1.99 frother at Ikea.  Makes the cleaning process easy - that's what I use at home, never used the steam wand on my machine.
To use the frother, just heat up the milk and froth away.  Pretty easy.
Nov 20, 2007 | Krups Caffe Bistro 867 Espresso & Coffee...
KitchenAid Artisan Logo
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
