Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE side-by-side freezer losing power
Progressively over a period of a month or so the freezer seemed to be losing its freezing power to the point where some contents of the freezer were defrosting. We cleaned it out and took off the panel at the back of the freezer compartment to find that it was pretty-much solid ice around the brush-like bits. We defrosted it all and the freezer then seemed to work fine for a week or two but it is now losing freezing ability again. I would welcome advice.
Thank you
James Norman
Auckland, New Zealand
    President:
  • 2,976 Answers
Before messing with the wiring and heating things up so much, FIRST, check the door seals. Put a dollar bill between the door and cabinet at various places and shut the door. When you pull it out, you should feel resistance. If not, replace the seal. Check the back of the unit where the pipes go into the freezer. It probably has a metal cover over it and that needs to be removed. Look for mouse damage. ANY openings at all will allow warm room air into the unit. Finally, remove the inside liner of the freezer. Look for ANY ice buildup. Melt it away and put things back together.
Heating your defrost element to a "RED GLOW" will quite possibly burn it out.
Posted on Jul 19, 2010
  • GE Master
  • 1,606 Answers
My c/p solution to your problem .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
Posted on Jul 18, 2010
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Jul 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water inside bottom of freezer.
Water accumulation in the freezer more commonly points to the ice maker. Over a period of time, water entering the ice maker can slowly freeze to the point it provides a small restriction and prevents a portion of the water from entering the ice maker. The plastic spout/tube could also have either cracked or shifted and is allowing a small amount of water to leak into the freezer.
Feb 24, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Ge SIde by side SSS25KFMDWW stopped freezing
number one,is the freezer fan working?2,is there frost forming on the back wall of freezer?let me know more-mike
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile CF24W-PL
Its simple really,, Your refrigator needs re gassing,, call a professional and he will regas it.
When the gas is running low the fridge cools less and less and eventually will not cool at all when the gas is depleated. Its a natural process and any aircondition or refrigation professional should be able to come to your house and gas up the refrigator , a process that takes a few minutes.. I dont recommend you attempt to do it your self, as it will not take a whole can of gas and if by chance you use the wrong type you will spiol the compressor
cheers
Jan 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
217 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
