Question about Hitachi Televison & Video
I replaced the convergence chips and when I powered the tv on I got no picture. It is model # 61SWX01W
    Brigadier General:
  • 8,619 Answers
Hi Michael,
Thanks for using FixYa. The issue seems to be with poor or loose connections of the IC you replaced. Please check and verify all the connections. I am assuming that sound on your TV is working and you are unable to view any picture on the TV screen.
Make sure that the focus lead is connected firmly (a wire going towards the focus block, in the front of TV set). Please be very careful while checking this as it contains a very high voltage of charge on it (between 10-30 KV). If this wire is fine then please check if you can hear any crispy or crackling sound from the inside of TV set. If yes then it's due to loose connections on the flyback transformer. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 18, 2010
Picture looks dark
I have same model. First set went out of convergence, and I was able to adjust it. A few days later I had same problem and fixed it again. Then I was no longer able to adjust it. I watched TV the way it was. The picture got darker.Then I was watching TV, and there was a flash from the middle of the picture, and TV powered itself off. I unplugged TV and plugged it in 30 seconds later. I powered TV on, and red LED on front panel blinked a few times, and stopped. TV powered itself off.
From what I learned, the LAMP has to be replaced, and so do the convergence chips and convergence resistors. The TV shop charges around $300 and up just for the convergence chips. The TV is selling on craigs list for $150 to $200 in good working condition.
You have to decide if the repairs are worth your while. Probably not in mmost cases.
Sep 24, 2012 | Hitachi 50GX30B 50". Rear Projection...
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or...
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Jan 01, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I'm getting an overlapping of two colors on the screen.
It is common problem with rear projection tv and 3D type picture problem occurs due to failure of convergence output ICs, replacement of convergence output ICs will fix the issue and tv will again show correct converge picture as before.
Let me know tv model number written on back of tv if you want to fix tv by yourself as it needs soldering parts in circuit board expertise and if you feel uncomfortable working in tv circuit boards than local tv repairman will do this job for you.
Thanks.
Jun 30, 2010 | Hitachi 61SWX01W 61" Rear Projection...
How do i replace my convergance chip
contact parts distributors who sell convergence kits for your model.
Order instruction DVD.
Jun 03, 2010 | Televison & Video
Colors are not focused. blurred picture. was told it was converganc. manual focus doesn't fix it. please advise if it's worth fixing. Fred C.
Yes,Ur tv convergence are dead.Must know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$350 for parts and labors.
Apr 12, 2010 | Hitachi 61SWX01W 61" Rear Projection...
Was having problems with a hitachi 61swx01w pictures out of what i belive convergance issue...purchased stk392-110 parts (two) didn't get to it for a while...now tv will power on but screen is...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 23, 2010 | Hitachi 61SWX01W 61" Rear Projection...
Convergence chips replaced, tv powers on and no picture
You have to replace the chip with the same kind, or at least crossed referenced, but still exactly the same but diffrent manufacturer.
Aug 15, 2009 | Hitachi 43FDX01B TV
My JVC model number AV-56WP30 has a flashing convergence screen
Your TV most likely has a Convergence Chip Failure but I have not seen that symptom before.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 28, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a convergence problem. My Sony KP-65WS510 has a picture that looks like 3-D and bows at the bottom and top of the screen. I already replaced both the IC's STK 392-560 (2 qty.) and check all six 3.5a...
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Dec 09, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Bent picture
The convergence circuits straighten out the edges of the picture, putting the 3 colors exactly where they should be for the picture to look normal. There are usually 2 large IC's that handle the 6 convergence channels and if one of them burns out then one of the colors bends dramatically. If the power supply for the convergence circuits stops working, then all 3 colors bend in, the colors do not line up with each other and the image looks almost 3D, and the adjustments in the convergence menu will have no effect. I would bet that is the case with your set - the convergence power supply has quit working. If you do not have experience troubleshooting power supplies and realigning convergence circuits in projection TV's then allow a qualified tech to handle it for you.
Aug 07, 2007 | Philips 51PP9910 51" Rear Projection HDTV
Open Questions:
My Hitachi 57F710E rear projection tv won't turn on after power failure. I have a Hitachi 57F710E rear projection tv that won't turn on. We recently had a power failure, the electric went off and on, off and on, and then off and stayed off. This happened in quick succession. After the power was restored the tv wouldn't turn on. I took the back off of the tv and checked to see if there were any fuses that might have blown. There was 4 fuses, 3 on the power supply board and one on another larger board that I believe says "deflector" on it. All the fuses were fine. We did the unplug and plug in thing like the book suggested and it didn't work, we even left it unplugged for 72 hours and plugged it back in, it didn't work. So, we decided to just move it out to the garage to get it out of the way. After we moved it out there I decided I would take the back off and take one more look at it. after I took the back off I plugged it in and I heard a slight click, it only clicked once. I also noticed that there was a small green LED light on the deflector board that was lit up, so I pushed the power button on the front of the tv and I heard the tv come on. I went ahead and hooked a dvd player up and lo and behold the tv was working fine. At that point I decided to go ahead and clean all of the optics. I then brought it back into the house and hooked all the STB's back up and plugged it in. The tv wouldn't turn on. It no longer makes that small click noise when I plug it in and the little LED light on the deflector board no longer lights up. Could someone give me an idea of what could be wrong. Thanks
Aug 09, 2018 | Hitachi Televison & Video
Televison & Video Logo
15 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
