Question about Whirlpool LGR6611L Gas Dryer
Intermittent heating on my Whirlpool gas dryer (lgr6611lq0). I have the back off and can see the burner come on for a bit and then go off. I have good airflow out of the dryer vent (at the dryer itself). Have thoroughly cleaned out the lint trap and the metal box the encases it. What should I be looking for next.
  • 1,998 Answers
Ok have u checked the hi and low relays for continuity these are both found aroundthat area as well and make sure you unplug yr machine before performing this test you also have an ignitor inside the unit which should be drawing 3.3 amps if it is lower then you should replace the ignitor hope this helps
Posted on Jul 18, 2010
LG5791XSWO
The symptom you have indicates weak solenoid coils. The gas valve should open and the burner should ignite every time the glow bar igniter glows before it fades back off. Weak solenoid coils will usually open the gas valve until the solenoids become hot from the current and flame and then they don't have enough power to open the gas valve.
Replace both solenoid coils and your dryer will most heat and operate normally again. In order to access and replace the solenoid coils you will need to remove the front panel.
Here is the coil kit to order.
Nov 06, 2012 | Whirlpool Dryers
I have a Maytag MDG9606AWW gas dryer. The heat is intermittent. What part is most likely to need replacing?
Although it could be several things, the three most likely suspects is the radiant sensor P/N 338906, the thermostat P/N 303395 if there is a temperature fluctuation but the burner is active. The gas valve P/N 306176 if the burner is not active. Intermittent problems are very hard to troubleshoot so you need to write down every indication and when it happens. For example: Works good on permanet press, but not on high.
Hope this helps. Hal aka ImJustAvg
Dec 17, 2011 | Whirlpool Dryers
It takes forever to dry clothes (on Medium Heat Setting). For small loads (4-5 articles of clothing) it takes 2+ hours to dry, and even then it's slightly damp and cold when I remove it from the...
sdf
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
so clean your vents and filter forst
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 24, 2010 | Dryers
Gas whirlpool dryer model LGR6611LQ0 will not heat up . Ignitor turns on but will not light
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Whirlpool LGR5636L Gas Dryer
Whirlpool dryer model LGR6611LQ0 will not heat up
check for tripped breaker and proper voltage, next check to see if turns on if your getting air to the outside vent if ok the you need to open the unit up (unplug it FIRST) your be looking for the thermal fuse and or the cutoffs these will be attached to the blower housing assy ohm them out and also if electrical one check the heating element as well most cases this will solve your problems
Aug 15, 2009 | Whirlpool LGR5636L Gas Dryer
HEAT ONLY STAYS ON FOR A FEW MINUTES. WE HAVE ALREADY CLEANED OUT ALL THE LINT FROM EVERYWHERE.
replace the 2 coils on the burner . After they warm up , one will "short" , therefore the gas will not come on unless cooled down for a bit .
Aug 14, 2009 | Whirlpool LGB6300 Gas Dryer
My whirlpool gas dryer will not heat. I replaced
there is a big black box on top of the burner check this if good check theremal fuse this will be on the heat tube most likly in the back it is small and white
Jun 26, 2009 | Whirlpool Dryers
Whirlpool Dryer LGR6611LQ0 will not heat up
there isn't a pilot you have an electroic ignitor in there part number 279311.there also is a sensor,gas coils and the gas valve,you need a meter to read them out,you said you checked the breaker and cleaned lint out ,is it dead?read out the thermal fuse first part number 3392519 located on blower wheel housing,unplug the dryer before you do anything and pull off one of the wires on thermal fuse then read it out hope this helps
Mar 22, 2009 | Whirlpool LGR6611L Gas Dryer
How to remove fan from dryer motor LGR6611LQ0
ok corvett your there you just jumped one step..put the motor back and put the 2 motor clips back on,,,ok,,,,now you need to hold the belt side with a tool a grip pliers,,a wrectet head with handle turn which ever tool handle so it will hit the side of the cabnit the right side looking from front,,now wedge that tool..be careful go behind ,,put on worh gloves a must the side of blower wheel housing are sharp..caution got your gloves on,,now turn it to the left not the right,,counter clock wise..onthejob
Jan 09, 2009 | Whirlpool LGR6611L Gas Dryer
Whirlpool LGR6611L Gas Dryer Logo
423 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
