Question about Frigidaire Freezers
Power to the freezer light is on . freezer wil not come on
  • 388 Answers
Dear sir/madam
please check inside of your freezer there is one device thermostat make sure its needle is located in freezer,s cooling box or check circuit board there is can be an fault in electricity circuit . if its not on then please contect to your freezer maintenance personnel for futher action.
hope answer the question
thank you
please vote!
Posted on Jul 20, 2010
Beco freezer has red lock light on what is the problem
Most freezers use a red neon power light to warn if power supply is interrupted No light=no power.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 11, 2017 | Freezers
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
Power surge on ffu2065fw2 , what wil it do
Hello friend, thanks for your post!
I see that your Frigidaire freezer had a power surge and you're asking what could happen. If your appliance had a power surge it could cause an issue within the board or wiring harnesses. Is your appliance giving any error code or beeping? If so, could you advise what it currently is doing? I look forward to providing you any assistance. -Matt
Aug 22, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
Magic Chef Chest Freezer MCCF5WBX is not getting power, green light not on
Check your outlet with something else that will work, like a radio. If the green light does not come on, then check the wiring. The green light should be on even if the freezer has reached it's temperature. That is simply a light to indicate that power is at the receptacle.
Jan 27, 2013 | Magic Chef Chest Freezer MCCF5WBX
Where is the defrost timer located
Most residential units have the defroster clock in the base of unit towards the rear. It will probably be attached to a bracket with 2 screws. 3 or 4 wires wil be coming off it. ;)
Aug 20, 2009 | Freezers
New fan light running continuosly
lets see if i can help you out here, okay . Red is your hot power wire, Green is the ground which is screwed to mounting plate, black is negative, meaning no power.... connect your wires by color Red to Red , Black to Black , And if there is a green coming from the ceiling connect to mounting plate of fixture or vise versa. Remember to use eletrical scew caps, on all connections and do not leave any wires uncovered. Basically all your doing is a seperation of a wire from wires as you seperate a wire cap it off. then move to the next set and do the same. red to red black to black green to mounting plate . YOU WIL NOT BLOW ANYTHING UP IF THERE IS A WRONG CONNECTION, if all wires are of color follow these steps, if no color switch one wire try switch and vise versa YOU can do it
Jun 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
No light on door and motor not running
Have you checked your breaker switches in the circuit box? If tripped, the breaker will rest in a half way position.
Turn it all the way off and then back on.
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Fridge is not cold but the light will turn on...
if its a fridge freezer fully defrost it 48hrs
Feb 07, 2008 | Freezers
Freezers Logo
285 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
