Question about Kenmore Dishwashers
Dishwasher is not washing the dishes especially the upper rack
  • Kenmore Master
  • 43,501 Answers
Check your heating element..
Dishwasherdishwasher is not washing the dishes especially - 2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jul 18, 2010
My Hotpoint dishwasher works fine except that it will no longer wash the dishes in the top rack. It's like the water is not coming up far enough from the bottom to do the job.
There should be an upper spray arm to wash the upper rack, it may be stuck. Look at its position, run the machine a few seconds and see if it moved. The spray nozzles on the arm often get clogged with food particles. the pipe feeding the spray arm has to extend when you pull the rack out and retracts when you push it in. Make sure it works properly and has not disconnected.
Sep 04, 2017 | Hotpoint Dishwashers
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
Sep 13, 2014 | GE Dishwashers
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
Kenmore 3380957 rev a won't get dishes clean
Make sure that that upper arm is free to turn. Check it while you have dished installed, because sometimes, dishes on the lower rack may stick up too high and hit it. Otherwise, check the back of the water-supply tube attached to that upper rack.... Is it lining up with the water feed port or hole at the backof the dishwasher? Is there a gasket that is either ripped or missing? And check that wash arm carefully.... Might it be split or bent? Are the holes on the bottom clear? (Those holes are usually angled to push the arm around; if they are clogged, the arm won't rotate.)
Mar 15, 2012 | Kenmore Dishwashers
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
The top rack of dishes are not getting clean. I
you need to check the upper wash arm for blockage from debris,if this is not the case,then you need to replace the water conduit from the lower sump area to the top arm,after time the water erodes the plastic conduit especially where it connects at the arms and water gets by these areas and can no longer build pressure to spin the wash arm
Apr 19, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Dishes not clean?
Check all the water jet orfices in the moving arm. Try cleaning without loading the top rack.
If cleans well, mostly the upper rack dishes not arranged properly.
I hope you are using the main wash detergents. Rinse aid is just to remove the stains after the main wash rinse.
Apr 01, 2010 | Dishwashers
Kitchen aid dishwasher not cleaning dishes well. especially the top rack. practically taken the whole thing apart can't find any clogs.
sounds like you have a broken chopper. have you checked the chopper how far have you taken it apart? if the unit is put back together point all wash arms in the same direction turn the dishwasher on after it has started washing give it about 2-3 minutes open the door and see what wash arm is not moveing. if the upper wash arm is not moveing you need to check the chopper.
Oct 18, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Dishwashers Logo
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
