Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Dishwasher hums loudly while running
Dishwasher was virtually silent until a week ago. Now it hums pretty loudly.
Haven't changed anything and rinse dishes thouroughly before loading them. Any ideas?
  • Anonymous Sep 27, 2008
    Kenmore elite model 17599, black front/stainless interior.  The dishwasher makes a humming noise during the wash cycle only
  • ottsabre Mar 02, 2009
    I have the same problem on my Kitchenaid KUDS01FLSS1 dishwasher. As soon as the water during the fill cycle is done and the wash cycle starts, there is a very loud hum. I opened up the chopper assembly and there doesn't appear to be anything caught in the screen. Any suggestions would be appreciated.
Very likely pump motor shaft seal leaks water into bearing casing buildup of rust and consequently noise. I just replaced $112 worth of pump assy and it's back to normal. I would also buy repair manual for $10 on-line to be sure how to disassemble the sump to get to the pump.
Posted on Apr 08, 2012
    Genius:
  • 1,073 Answers
If this hum is in the wash cycle then dissasemble the top of the pump assy and look for foreign objects in the pump
Posted on Apr 22, 2008
What is decimal level of
If you are asking about your dishwasher I am going to guess you mean decibel level. Decibels refer to how loud the sound is. If you are interested in knowing about how loud your machine is, 45 decibels is pretty silent while 50-60 is about a normal conversation level and the average dishwasher machine is 52 dB. A vacuum cleaner is about 70.
Aug 31, 2014 | Dishwashers
Utilitech jet pumps
This sound could be many things. It could be cavitation from a suction obstruction. IT could be a bearing or a bushing. IT could be something lodged in the impellors. YOu will have to take it out and disassemble it to see.
Dec 09, 2013 | Plumbing
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
GU1500XTL loud humming sound during the cycle, getting louder
The run capacitor on the main wash motor needs replacing. Eventually it will just hum and overheat instead of rotating, so better replace it now before it overheats.
I doubt you can acces it easily yourself, as it may be away from the motor, and have to be tracked down.
Aug 05, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
The cups and silverware come out with food on them
I recommend rinsing the food off before placing the items in the dishwasher. Also, run the hot water in the sink until it is hot before you turn on the dishwasher. good luck
Jan 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher making loud humming noise
The most common cause of the hum/grinding sound, and often poor cleaning - is a blocked filter or debris stuck below that filter.
Pretty easy fix: Get a phillips screwdriver near by. Pull out the lower rack (the upper rack can come out if you pull the little gray thingeys on the front of the upper rails.)
Remove the lower spray arm -- just pull it straight up. Remove nine silver screws from the sump area that holds the filter down. Pull the filter up and out. Rinse the filter as best you can.
While the filter removed, with a flash light inspect all over the sump area - looking for stuff that should not be there and clean it out. Watch out for broken glass!
Replace the filter, screws and the spray arm. Fire it up and check your results!
Good Luck!
Oct 20, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
Loud Humming Noise
You're describing vague, conflicting information. At first glance, I would think you have something stuck in the pump. But then it would be there in the rinse-only cycle also.
The anti-bacterial mode heats the water up to about 180F. This kills bacteria, and it also speeds up the action of the detergent. It could be dissolving whatever is in there.
The humming noise wasn't there in the rinse mode... The heater isn't on in the rinse mode - everything else is. But I've NEVER heard a heating element hum.
Cleaning the filter:
The filter is in the back in the bottom right. It's cover is held on by two 1/4 in screws. Under that is a large grate, and I sometimes find stuff clogging the screen (underwater, toward the center of the machine.) I'd start by looking there.
Mar 23, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
833 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
