Question about Fedders A6P09S2A Air Conditioner
How often do i dump the water build up - Fedders A6P09S2A Air Conditioner
  • 70 Answers
Depends on the humdy in the air. The more hundy the more you will but check it every 4-6 hours. It should have an auto cut off when it fulls up.
Posted on Jul 18, 2010
Where can a get a Part for a Pagasus Toilet .
You can adjust the water level so more water comes in so it fills higher to flush
Jan 25, 2018 | Home
Sears ice maker
Does the motor makes a noise when you try to get ice?
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice build up in freezer bottom
check the ice maker 's water delivery trough. It may be dumping water overboard.
Jul 24, 2014 | Whirlpool Refrigerators
Not making enough ice
What is the ambient air temperature in the location it is installed??
Aug 27, 2012 | Ice-O-Matic Ice o matic Iceu220a Cube Ice...
The ice maker is dumping water on the floor and building ice in the despencer where you puy your glass
Usually when this starts happening the refrigerator inlet water valve need to be replaced. It is leaking water by the diaphram when the water is supposed to be off. I have seen this probably 100 times..... almost always is the inlet water valve.
You did not provide a model number so I can not provide you with a parts link,
Thanks for choosing FixYa,
Kelly
Jan 29, 2011 | Magic Chef Refrigerators
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Refrigerator icemaker won't work and refrigerator fills with wate
check your fill tube you might have an ice build up on the end
the fill tube is where the water dumps into the ice machine
Oct 03, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemake rarely dumps ice and when it does they are small cubes
There has to be a restriction in the water supply line from your saddle valve, ( shut off valve on the cold water line ) to the water valve. It can be in the category of, the hole in the water supply line is getting calcium build up or to small of piercing, or it can be a kink in the water line, or even the white fill tube at the icemaker is closing up with ice. 99% sure you will find the problem in one of those areas.
Apr 23, 2009 | Maytag MSD2732GR Side by Side Refrigerator
No water is going into the trays
check water valve or filter icemaker befor calling service see if you have frost build up in freezer
Apr 02, 2009 | Admiral 26 cu. ft. Side-By-Side...
Steam sauna (mr Steam ms400tc1). Unit fills up then allows water to exit via steam head without heating up to steam. Unit should stop water entering heating tank when full, heat up to steam, then allow...
If that unit has a steam valve I'd suggest checking it to ensure it's not stuck open. If it is, the steamer will not build pressure also. Should be a gauge for tank pressure that will show if it has built up pressure. If the valve is stuck open, it may certainly just dump water instead of steam. It's possible the water level sensors are allowing too much water into the tank, and as a safety it dumps. I've changed steam valves quite often due to the amount of heat they have to deal with.
Sep 16, 2017 | Heating & Cooling
Fedders A6P09S2A Air Conditioner Logo
126 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
