Question about Bose Wave radio remote control - Graphite Gray Shelf System
Need help changing batteries on Wave Radio remote
I have a Bose Wave Radio 97 year model with remote. How do you change batteries in this remote? (This model is radio only, no CD player) Remote is correct one for device.
  • 4 Answers
Setting up the remote control
WARNING: Keep the remote control battery away from children. It may cause a fire or
chemical burn if mishandled. Do not recharge, disassemble, heat above 100°C (212°F), or
incinerate. Dispose of used battery promptly. Replace only with a battery of the correct type
and model number.
Your remote control may be one of two types. Each is identified by the way
the battery compartment unlocks to install or replace the battery.
1. Place the remote control face down on a flat surface.
2. If your remote has a slot on the back, follow step A. Otherwise, follow step B:
A. Insert the tip of a ballpoint pen into the slot. Push to the side as shown and hold. Slide
the battery compartment open with your finger.
B. Using your finger, push the tab lock to the side as shown and hold. Slide the battery
compartment open.
Setting Up
See operating
instructions for types of
battery to be used
Note: Use only a Duracell, Eveready, Maxell, or Toshiba CR2032 or DL2032 lithium battery
(available at electronics stores). If you have difficulty finding a replacement battery, contact
Bose® Product Support (see phone numbers on the inside back cover).
3. Keeping the remote control face down, insert the new battery into the compartment with
the + symbol facing up.
4. Gently slide the battery compartment closed. It locks automatically.
5. Use the supplied mounting strip if you want to attach the remote to a surface in your
listening room. Peel off the protective backing to stick one piece to the back of the remote
and the other to the selected surface.
Posted on Nov 04, 2010
  • dominic629 Nov 04, 2010
    if you need to see the illustrations just google "bose wave radio manual"
No sound Bose wave
I took mine back to the Bose store and they gave me credit on my Wave that was about ten years old toward a new CD wave radio. I would recommend taking it to the Bose store and see what they can do for you.
Sep 11, 2014 | Bose Wave Radio
How do I turn radio on? Is there an old-fashioned "on/off" button? The battery in the remote needs to be replaced but in the meantime,is there a way to turn the radio on?!?!?! Many thanks!
If you have new generation of Bose wave radio with no buttons on the top, it would be no other way, but with remote. Need to know the model number.
Dec 07, 2010 | Bose Wave Radio
Remote does not work, battery is good. Can I program my dish network remote? If so what codes can I use.
Sorry to hear about your original remote; we would be happy to help you with addressing your DISH remote to your Bose Wave Radio. Here is a list of some of the codes that we havefor Bose Wave Radio: 761, 664, 656, and 639.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Bose Wave Radio provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Bose Wave Radio. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
Nov 21, 2010 | Bose Wave Radio II
The remote for my Bose Wave radio-CD no longer works. I have changed the battery and put a new battery into another Bose remote--no luck and I want to play my Christmas CDs! Help!
  • Reset the system by disconnecting the power cord from the wall for one minute, then plug it back in
  • Make sure you’re pointing the remote directly at your Wave® music system. If the system is placed above table-top height, be sure to angle the remote upward while pointing
  • Check for possible sources of interference with the remote’s infrared (IR) signal, such as bright lights or solar glare off of a window. Make sure nothing is blocking the path of the signal from the remote to the Wave® music system display. The remote will not work properly if there is something directly in front of the display
  • Wipe off the small clear lens on the front end of the remote
  • The remote is designed to work within 20' of the system. Greater distance may cause intermittent response
Dec 05, 2009 | Bose Wave Radio
CD player has no sound - Bose wave radio/cd player
Amplifier chip/circuit is kaput. Unless you are familiar in fixing electronic equipments better to give it for repairs................sodeep
PS. Buying a new one will not be cost effetive unless you need a change!
Jun 28, 2009 | Bose Wave radio/CD remote control -...
I HAVE A BOSE WAVE RADIO AND THE VOLUME WILL NOT WORK
Change the batteries in the remote, or manually change the volume with the up and down arrowed buttons on the top of the unit.
If this does not suffice, let me assure you that Bose will take good care of the service end of their relationship with you.
Apr 07, 2009 | Bose Wave Radio
Remote
I changed the battery in my remote, and it works fine.
Oct 22, 2008 | Bose Wave Radio
Remote control problem
Replacement remotes for my AWR1 were $10 from Bose. Order online; receive by mail. I just bought two.
Jun 01, 2008 | Bose Wave Radio
Radio multi cd changer
need to get u new remote on ebay they have them or remotewarehouse online what model do u have have u try changing battery in it 1st
Jan 31, 2008 | Bose Wave Radio
652 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
