Question about JVC AV-48WP74 48" Rear Projection HDTV-Ready Television
Suddenly all of a sudden
Turned on the tv, was showing d-17, i hit channel up, it went to d-18, so pretty much was showing d, i guess that means digital, not sure how it switched over to that , but then, after getting the channels to reappear, the picture is fuzzed over with a tint of green, cannot seem to get the picture back to normal, any suggestions? i hear about the ic and i'm aware of what it does, however, why would it suddenly malfunction, could it be something else, based upon what i previously stated with the channel swicthover to digital? thanks for any suggestions you may have!
    Problem Solver:
I have a JVC AV48WPT4 48 Inches. Have perfect picture but fine retrace lines on the screen.
Can you tell me what could cause it?
Thank you.
Posted on Apr 30, 2008
Why did my sanyo 19" hdtv all of sudden went black? what to do now?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 12, 2014 | Sanyo DP19647 19 in. LCD TV
TV is suddeningly turning volume up and down
That could be one of two things first being the front keyboard and possibly a main board. However the keyboard is usually the cause of those two issues. You can get replacement boards with free tech support for diagnosis to determine which board you actually need at www.tvrepairworld.com just hit the contact us button and enter the model number and symptom
Aug 05, 2012 | Emerson LD195EM8 19 in. LCD TV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Oct 18, 2009 | Sony KV-36FS100 36" TV
My 6 to 7 yr old television suddenly went dead
There is a board that manages the power going into your tv I would check around with local mom and pop tv reapir shops. The board is not expensive its the labor I am not sure where you live but I am sure there are local techs that work on flat panel tv's. They are pretty affordable these days. Most flat panel tv's are rated for 60,000 hrs as there life span. Hope that helps
Mar 25, 2009 | Panasonic Televison & Video
Black square appearing on tv
turn off closed captioning
Nov 29, 2008 | JVC AV-27530 27" TV
Screen blackout
I had the same problem and fixed it with a new backlight inverter board. It was a pretty easy install. The part is available on eBay. http://cgi.ebay.com/New-Inverter-for-Dell-W1700-17-inch-LCD-TV_W0QQitemZ400017456720QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Nov 07, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Symphonic 20" television will only get three local channels
I suspect your tv has gone back to air and should be in cable mode; you will have to go into menu where channel programming takes place. Select cable and autoprogram; it should pick up the missing channels.
Jul 16, 2008 | Symphonic ST420FF 20" TV
"my tv just went out"
Most likely your lamp has failed and your owners manual will show how to replace the lamp.
Nov 21, 2007 | Zenith D52WLCD 52" Rear Projection...
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
270 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
