Question about Sony Cyber-shot DSC-W55 Digital Camera
Camera has a message coming up on screen sayng to turn camera off
Each time i turn my camera on a message comes up saying TURN THE POWER OFF AND ON AGAIN. I can't take any pictures!
    President:
  • 1,382 Answers
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the isopropyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you!!
Posted on Jul 18, 2010
I dont want to see the little preview of text messages that turn up on our home screen when a new text (SMS) message comes in.how To turn this off in samsung grand 19082
Most of the time if you open up your messages and open the Message settings there will be an option to Turn Off Message Notifcation Preview or an option that says "Display only Phone number", "Display text message", etc. Just select the one you want.
Nov 30, 2013 | Samsung i9082 Galaxy Grand Duos Dual SIM...
Camera will not come on, it says "turn the power
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Jun 19, 2011 | Sony Cybershot Dsc-w290 W230 W220
When i turn on my camera the lens gets stuck coming out
Normal batteries it's not working for me!
After i replace standard alkalines with rechargeable NiMH batteries Sony and Varta 2700 Ni-MH it's was working!
Jul 16, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
There is a flashing number inside the screen that I cannot remove, and my pictures are not coming out as they used to.,.they are very dark,,.how do I remove this flashing number it says 91:01
Just follow the steps below to remove the error message.
Turn off camera.
Remove the battery or the power supply.
Turn the switch to CAMERA for about 30 sec.
Turn the switch to OFF.
Install the battery or power supply.
Turn the switch to MEMORY.
Open the LCD cover and press the RESET button .
You will be prompt to adjust date/time. Do take some pictures.
Hope this helps.
Thanks for using Fixya.
Do rate the solution.
Dec 14, 2009 | Sony Cybershot S650 Digital Camera
SONY CYBER SHOT NOT WORKING
Hello samtx930, "turn off the power and on again" its a very commen problem and occurs when the lens block assembly start malfunctioning. Actually the slide motor not work properly and until the lens not come out completely the camera will not work, that's why the error message appears "Access" and then screen shows "turn off the power and on again". In this situation you have to replace lens block assembly.And the part No. is with description is given below: 1-788-363-11 OPTICS UNIT (ED13A) Thanks for using fixya.
Jun 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Another application is running. Close it then start the camera. ?
it is either the camera hardware is ffaulty  or u need to reinstall the firmware
Mar 06, 2009 | Sony Ericsson K770i Purple 3G Camera...
Mavica CD400 won't take photo
problem with the lens, try taking it out and putting it back in
Jul 30, 2006 | Sony Mavica MVC-CD400 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
176 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
