Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Deck is cutting uneven - Craftsman 42 in. Deck 19.5hp Lawn Tractor
  • 51 Answers
First check tire pressure if even check to see if deck hangars are still conected to deck if somay need to be adjusted only one side is adjustable.if changed blades make sure one is not up side down, also make sure blade spindles bearings are good
Posted on Jul 18, 2010
Deck not cutting even on murray model 38515x92
if is uneven the deck needs to be leveled you must have removed it and put it back uneven check both sides where the deck attaches bet one is lower than the other
Sep 23, 2013 | Murray Garden
My 42inch craftsman deck does not have wheels on it to keep an even cut.....is there some type of adjustment on the deck itself......it is cutting uneven
There is one thing that commonly causes the deck to cut unevenly. The mandrel/spindle has one of the ears cracked. Probably have to remove deck to get a good look at all of them.
If you want antiscalping wheels for your deck, they can be purchased and added to the machine.
I hope this helps you out.
Aug 01, 2011 | Craftsman Garden
I have a problem leveling my mower deck. I level it at the sides and front .I use the mower and it cuts uneven. mower is deck is out of alignment. less than 1 hour on it.
The deck could be bent, or you will probably have to level the back of the deck as well. Another thing to check is the air in the tires, this can cause an uneven cut. Although the tire may look pumped up, with the weight of a person on the tractor can cause an uneven cut.
Aug 10, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
I have a Craftsman 42" rider cuts uneven
Check your tire pressure first, uneven tore pressure will cause this problem.On the rear of cutting deck on both sides there are height adjustments, if your deck has a rear roller this also can be adjusted to compensate,If your a stout person sitting on tractor can cause unevenes.
Jun 25, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Uneven grass cutting
I have seen dull blades, blades not installed right and an un-level deck cause that.
Hope this helps.
Sep 21, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Deck unlevel cutting unevenly
with deck up,, take a ruler and measure mid way each side,,if off you have nut on the deck you can screw up to raise,doen to lower,, but if side to side level,, then you have 2 rods at the front at the front axle, measure the rods and make sure that both the same length if one is off turn to match the other,, but if you turn both make sure you turn both the same turns,, hope this help you,, good luck
Aug 09, 2009 | Garden
Uneven cut
I suggest you park the tractor on a level hard surface. Measure from the bottom of the deck to the ground on both sides of the deck to see if it is mounted level. The next thing to check for is a bent blade. Good luck.
Jul 06, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
My deck cuts shoter on the rt,ie uneven
Check your tire pressures:
10 psi. for rear tires.
14 psi. for the front.
Note that according to MTD:
Making sharp right hand turns. Twin-blade mower decks are designed with the discharge on the right side and two side-by-side blades. The side-by-side twin blade decks have the left hand blade positioned slightly forward and in front of the right blade. This provides cutting overlap when traveling in a straight line. As a result, the tractor should mainly operated making primarily left hand turns when cutting. During left turns this cutting overlap is maintained. If turning right when, it is possible to negate this overlap and leave an uncut strip.
May 31, 2009 | Mtd LAWN MOWER PART # 683-0439A DECK...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
205 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
