Question about HP Hewlett Packard Pavilion Slimline S3100N PC Desktop
Computer turns on but won't boot doesn't wake up monitor and it is beeping.
    Problem Solver:
  • 8 Answers
Try resetting your bios (i.e. hold power button until it comes on, then goes back off, or taking out your cmos battery on the motherboard and hold a paperclip across the metal prongs for 15 seconds then replace battery) If that doesn't help, then I'd look at possibly a powersupply, ram, or motherboard failure
Posted on Jul 22, 2010
Power flashes on for a second and then turns off completely
The most likely problem is that the power supply has failed.
Jul 19, 2013 | Shuttle XPC SD32G2 Barebone
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Dell inspiron530 won't boot and beeps four times stops and beeps again
The Beeps are a beep code 4 means you have a ram read/write failure. Or a possible motherboard failure in that case you will need to contact Dell or replace it yourself.
Oct 01, 2012 | Dell Inspiron 530s Desktop Computer
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
I have an AOC e2243Fw series monitor, less than 2 months old. i recently moved my computer from one room to another. Plugged all the cables in. My cpu works fine, but m monitor is telling me no signal. I...
You have problem with computer. Is you video card is built in. if not reset the video card of your computer. Full it up the card and return i again to the socket. Then check your monitor.
Sep 08, 2011 | Computers & Internet
My HP w2007 has started clicking to Monitor Going to Sleep and then going blank. I have never known how to wake it up so I have to turn the whole computer off and restart. HELP
Hey there, Normally simply pressing a random key on your keyboard or moving your mouse should wake it up, if it doesn't though I think the easiest way to solve this is to simply turn off the sleep mode after x amount of time.
If you have windows 7, press the start button and type in "power options", go ahead and open power options and there you will be able to set the time it takes before your PC shuts down, and you can also set it to never.
If you still wish to use this feature but just want to be able to it's a bit tricky and it won't even work for all PCs but if the keyboard waking isn't working, then it's probably because your pc does have this feature. When your PC is off, boot it up again and enter the bios by pressing F10 i believe it is for HP. And somewhere you should be able to set which devices are allowed to wake up your computer, all devices are probably disabled now, so go ahead and enable the keyboard to wake up your computer. Now save and exit, and the next time your PC goes to sleep mode you should be able to wake it up by pressing a key on your keyboard.
I hope I was able to assist. If I was, please don't forget to rate this solution.
Jul 28, 2011 | HP Pavilion F1523 15" LCD Monitor
I have a dell dimension 4600 computer. I usually put the computer in sleep mode when I am not using it. Usually I press the ESC button and the computer wakes up. All of a sudden, the monitor won't...
Plug the monitor into another computer to determine if the monitor is damaged or working properly. You can also plug another monitor into your computer to determine the same thing.
May 21, 2011 | Dell Dimension 4600 PC Desktop
My CPU is on but no display in the monitor.
may be your video card is broken.. try to barrow a monitor from your friend or relatives and test if the problem is in your monitor or video card..
Apr 18, 2011 | Computers & Internet
My monitor will not wake up
I wm having this same issue. Dis you ever get this resolved? princess242@comcast.net
Oct 17, 2009 | HP W2007 LCD Monitor
Acer X223W monito won;t wake up after sleep.
I have a dual monitor system, both are the x223w. Same problem but only on the second monitor. Backlight shuts off.On/off light stays blue. I have to turn off the monitor and turn it back on. I returned it and Acer could not find any problem so I got it back. No problem for awhile and now a few times over the past couple days. Not good...
Aug 10, 2009 | Acer 22" X223w LCD Monitor
HP Hewlett Packard Pavilion Slimline S3100N PC Desktop Logo
232 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
